January 22, 201214 yr Author Hi Adgjm90, The item you circled is a lower link arm to be held in alignment by the two 1/4 x 2 x 14 jig pieces for the purpose of welding. The jig is used for welding each lower link arm and also for welding the upper link arms. By using the jig I found it simple to end up with all four links that fit together without any modification and makes parts that are interchangeable (left to right). With the jig you can make replacement links which are exact fits. Ted
January 22, 201214 yr Author I keep all dimensions the same as Clay's plans except as I noted in the drawings and text above. Ted
