OA Torch Question
Hello folks - hope this is the right forum to post this question.
I'm drawing a complete blank for some reason - I've seen these setups that can be used as part of an OA torch, where you can use the torch and then set it in this device/stand - it then cuts off the flame/gas, but re-ignites once you lift it off this stand (assuming there is some type of sparker of igniter). Sounds like the device is plumbed to regulators/valves that control gas flow/based on the postion of a lever that holds the torch.
Anyone know what I'm talking about? I saw it in a Peter Parkinson video - he was using it to help perform a series of twists in a bar, in which he had to put down the torch to re-orient material, then picked it back up to use. Lots of ON/OFF time, so to speak.
A pic/brand or web reference would certainly be appreciated!
Thanks, Mike
