used taps a blade steel?
Drifter
The advertisement at the top of this screen for taps indicated that they had two quality level: HSS and Carbon Steel. If you can find the carbon steel type, they might make a decent blade. I would guess you would treat them like a high carbon steel and oil quench them and experiment with the temper.
Thanks for the quick replies. I am just getting started in this addiction. Later as I have learnned some I am hoping to do some damacus steel blades and that would be my main intent on using the taps.
Drifter
the best thing to do is try it and see! at best you get a blade that works and at worst you get a broken bit of steel and the experience. ;)
I've turned old drill bits into small blades and they worked fine.
Any steel can be reforged and heat treated, just some are harder to reforge and heat treat than others! :D
