Hello everyone,
I have no idea if I am in the correct forum for this or not because this is my first time, but I picked what I thought was closest. I have recently built a 3 burner propane forge 8"X12"X24" long and I am having a bit of a problem. Long story short, I have diagnosed the problem and found out that the problem I am having is a build up of pressure inside where my burners are and no where for that pressure to go and in return I am not getting the Correct ionizing flame I need. Don't get me wrong, I am no expert by any means, the way I found this out is because if I blow through the forge with an air compressor, or even my mouth, I then start to get the correct flame I need. The only solution that I have came up with which might work or might not work, is to put a 90 degree flue on one end of the forge with an adjustment for the air to come in and go out. If anyone knows a solution for me other than completely rebuilding my burners, please let me know. Sorry for the not great pictures, I didn't know I would be posting this forum and am not available to take better pictures at the moment. Thank you all in advance.
Little more information, I am using half inch pipe until I get to top of burners, then it reduces to quarter inch. both top and bottom bell coupling is 1/2"x1.5" the nipples from top of burner to bottom of burner is 6 inches. Lastly, I am using a 30 psi regulator.
