Lenaghan
Everything posted by Lenaghan
  1. Hi everyone, never seem to post around here but am always coming back to get info so I thought I'd show what I'm up too. This is my secound try at this style, my first one devolped a big weld flaw right between the core bars and I decided to scrap it... This ones still has it's "issues" and didnt turn out exactly how I wanted it to but thats ok cause it's only for me not a customer! Outside Bars are 60 ish layers of 1075-1095, and on the last fold I decided to throw in 3 layers of saw blade(which I'm kicking myself for now, cause it throws off the pattern and just doesnt seem right) inner bars are 1075,1084 and sawblade all the different steel types was a way of cleaning out my cut offs, now I'm only going to use 1084 and real 15n20 here's the 4 bars all welded and drawn out and tacked together this is the welding of the bars making them all one This is a pic of welding the first sword, but it's the same thing... Now everthings welded and drawn out into a 30" byt 1/4" bar ready for rough forging For some reason I never took pic's of forging/beveling the blade but it no different then any other sword... here's some picks of the finished blade, all polished and sharpened just waiting for me to make the hilt Hope everyone enjoy's
  2. Lenaghan replied to Brad L's topic in Knife Making
    I gotta say I love that knife, I just think for a chopper its alittle too shinny... all that time polishing I'd be too worried about scatching it! Just joking around, great knife!
  3. I used to work at a metal fab shop with a very large bandsaw, I have no idea what kind tho but I've been using using the old blades with alot of luck. there very thin but about a 1inch to 1 1/4 inch wide. I've tested them and have no idea what kind of metal but there do get hard... Also since I've found it hard in Canada to get L6 or 15n20 I've been using those blades, and they do etch alot lighter and shine up nicely when welded with other 10XX metals here's a couple pics of what I've ended up with (keep in mind yours could be something completely different) this is 9 layers of bandsaw and 1084 this is around 75 layers of bandsaw, mild, 1075 and 1095 with a W1 edge hope this helps!
  4. I've seen on the net some pretty fancy stuff that would be nice to have, I would have liked one of those salt pots, but something about having a big tube of Lava just sit right with me... and I'm not ready for anything high alloy yet, my 1075 has been good to me!
  5. Lenaghan posted a topic in Swordsmithing
    Hi everyone, I havent posted here in a long time, or much at all but when I was starting out and gathering Info this site helped me alot so I was one of those I wanna make a sword first try type, and where I can say I did manage to make something of a short sword it's nothing I'm proud of and only keep it around to remeber how far I've came. One of many things I did learn from that attempt was that controling the heat, and being able to properly HT a large blade has huge problems that come along with it, 3 Years since I started and I've made a couple swords, several shorter swords, some little knives and have a huge pile of failed blades... and with every new blade I see huge improvements, but one thing I was still keeping me away from the longer blades was all the issues with the HeatTreating. So I built this thing... I just finnished the heat treatment of a 26 blade Jian and the thing worked great, and I could go as large as 40 inch Not sure what else anyone else here is using but I'd like to see what some of the more experianced people are doing
  6. Even if you dont think your skilled enough yet to forge a sword.. are you skilled enough to draw the bar out? I'm not sure what type of blade your thinking of making but you got alot of work befor you befor you can even think of forging in bevels and making a blade out of it. Some of the best pratice I think I've had is trying to keep a 30 inch piece of steel even and straight. If you want a taste of what it's gonna take to forge a sword, forge your bar down to 3/8 or 1/4 by 1 to 1 1/4 (depending on sword type) and from there when the times right you have a good starting point! best of luck -Michael Lenaghan
  7. I'm using Kaowool, but I went of and got a high alumina content refractory kiln furniture circle Im going to put at the bottom and have a layer of koawool under it. Not sure if it's going to work but I'm gonna give it a try. Oh and my finger learned that when you sharpen things, they become sharper...
  8. I learned that Borax really does ruin the inside of my forge lol :rolleyes:
  9. Lenaghan replied to ArtWerkz's topic in Tongs
    wow those are nice, whish my first set looked like that...
  10. My first forge was a fire brick one, and It took me a couple months befor I found a design I liked and finnally mortor'd it together. But thats the nice thing about the bricks is you can play around with it... try putting the burners on the side, then the top and change the whole size of it. this is also going to depend on the type of work your doing. I dont know if you where going to do something about the base, but you should get a metal plate and have it raised above your work bench. once the bricks heat up they stay hot for hours
  11. Hey a another winnipegger! I just finished building a new forge, so should be able to help you out i hope... for almost all the stuff you want except the steel and ITC 100 you can get from The sounding stone pottery place. http://www.soundingstone.com/store.do?dispatch=catalog&categoryId=143 half way down the page is the blacket and bricks you'll want. For ITC 100 I had to get it shipped from the states, after shipping and taxes it ended up costing alot but made a big difference. The shell of my forge is a old propane tank off a truck and works fine. If you need a propane regulator and hose I went to welder's supply. Good luck -Mike
  12. Looks sweet! I see crushed beer cans... :lol:
  13. Lenaghan posted a topic in Gas Forges
    Hi everyone, haven't posted in a while and just finnished a new forge so i thought I'd share. My old forge was made outta fire brick with 2 burners and it didn't seem to work that well, took a while to heat up and never seemed to get really hot so i figured why not make a new one, I got the idea of don Fogg's site. it's made outta a old trucks propane tank, 12 in wide and 13 high, with 3 in of Fiberfrax Insulating Blanket 2300 on the sides and 2 in on the top and bottom. ITC 100 covering the insides. 2x3 in opening on each side. I have a 3/4 burner in there now but could switch up to a one inch if I needed to. When I first fired it up I couldn't believe how fast it got to heat, and seems run hotter at 5 psi then my old one did running at 15 psi with both burners!!! plus I was seeing how hot I could get it and managed to make my first forge weld, It wasn't pretty but it was solid and i didn't have flux! so right now i couldn't be happier, and if everything goes good i could be getting my first real anvil in a week. anyways here's the pics...
  14. what size is your forge, or at least the opening for it? I just switched my set up from a one to a two burner(running a little rich). With the extra burner, one would seem to go out for a sec then relight it self... once I made a bigger opening for exhaust gasses it works great! good luck!
  15. Lenaghan replied to Lenaghan's topic in Tongs
    wow this is what i like about this site, everyones friendly here. And yes CurlyGeorge your right i do have the bug! I'm wanna make another set right away maybe outta better steel this time, to bad i ran outta propane and could BBQ supper lol
  16. Lenaghan posted a topic in Tongs
    hi everyone, I'm still new at this but had realized how badly I needed a good long pair of tongs rather then the vise grips I'd been using:rolleyes: So i found some rebar, and started hammering and this is what i ended up with... there not pretty but they work. I also used a bolt just cause I didn't know how to make a rivet. Also this is my first real project I've done start to finish
  17. HI
    Lenaghan posted a topic in Introduce Yourself
    Hi there, I just like to say I love all the info on this site, and wanna thank you guys for posting it up! I'm a welder by trade, but wanna start making stuff the old school way too :D
