TToch
    22
Profile Information
  • Gender
    Male
Recent Profile Visitors
  1. Thank you! I'm sure that some decarbonization has occurred, but not to the extent that it would effect the quality of the blade. I'm sure if I had a more controlled environment (gas forge or an even-heat oven) the pattern would almost be nonexistent.
  2. I keep trying to edit my comment, but the changes won't save. What I meant to say was no MAJOR decarburization has occurred. From what I understand there will almost always be small amounts of carbon loss in the surface.
  3. I don't believe it is, I am extremely careful during the heat treating process as I've found out it can make of break a blade. From what I understand (I'm still somewhat new to knife making) decarburization is the process of steel losing carbon due to excessively high temperatures, correct? If so, then no decarburization has occured, I try very hard to get my knives as close as I can to optimal temperature (with the minimal equipment I have) before quenching. And if there is another way decarburization can occur, I would love to know about it! I understand, maybe I'll try to get back into this weekend, thanks!
  4. Yep, no problem!
  5. When I heat treat my knives, I use a coal forge to bring them up to critical temperature for the quench (in canola oil). The knife gets this pattern from the thin layer of scale that develops while its heating. I've experimented with it a little bit and this pattern can pretty much be erased if you just brush the scale off right before the quench, but I like it so I keep it!
  6. As of right now, I'm going to stick to stock removal. I just find the process a little bit more enjoyable, but I might go back to forging once I get more experience. And yeah I really like the look of the scale pattern, makes each knife unique!
  7. Hello everyone, I wanted to show you all what I've been working on for the past couple of days. As I explained to another member, when I first joined this website I had posted a couple pictures of knives I forged from rebar, and I received a lot of critical feedback. Taking some time off I decided to heed their advice and purchase some good steel (1084) and begin making knives through stock removal. The first picture are my old knives and the other two pictures are of my new knives (which still aren't completely finished). I'd love to hear what you all think of them! (All of the knives are about the same size... Roughly 7 inches long, all 1084, with varying handle material) I am no longer in possession of the Bowie, as it was a gift for a friend. I intentially left the rough finish on all of the blades as I think it adds character, just a personal preference.
  8. UPDATE: I just bought the drill for $75 and it works awesome. Buying used is definitely the way to go
  9. I just went on Craigslist and found a 12" Darra James Drill press for $90. The owner claims it's in working condition. Think it would be worth checking out?
  10. After several attempts of drilling straight holes through my knives (with a hand drill) I've decided that I need a drill press. Lining up the pins can be kind of tedious and I just need more precision. My budget is $130. Anyone have any recommendations? There are so many to chose from and I think it would be best to hear your personal suggestions and experiences.
  11. I really appreciate all the replies. I think this will probably be my next purchase, since it seems like the best choice for my budget. I'm just eager to upgrade since it takes forever to produce anything with my current set up.
  12. Sounds pretty nice! Sadly I'm working with files and a harbor freight 4x36 belt grinder, not exactly the best tools to make knives with. Pretty much any belt grinder would work better than what I have now. Did you order yours offline?
  13. Thanks for the response, you definitely gave me a lot to consider. I'll probably just wait and buy a proper grinder once I have the money, I'm sure the wait will be worth it.
  14. I'm looking for a decent belt grinder, but I'm on a $350 budget (leaving me with little to choose from). I was searching around on the Internet and I came across these Kalamazoo grinders; does anybody own/use one of these? They're kind of obscure, I haven't seen a lot of people review them or mention them in the forums. I was curious to see if they are of decent quality or if they should be avoided. Thanks
  15. Alright, thank you
