david lange
Everything posted by david lange
  1. Thank you gents. I will scrape the crud off the case and see is i can find those screws. I did look down into the oil hole and the gears look good but dry.
  2. If you have a piece of the female spline just drill a hole in the end of the block and silver solder or braze the sleeve in the hole. Even if you do not have a femail piece of the spline it would be easier to make a short section by hand using files and than solder it in. It would make a difference if I knew what this was going to be used for. If its a slow turning machine you could possibly get by with drilling holes through your 6 in piece of stock and putting in stubby pins that would ingage the male part of the spline. Good luck and think simple...
  3. I have a champion 400 forge blower and it is tight and runs smooth but pretty dry looking in the grease hole. Two questions. How much lube do you put in the case and how do you get the case open? Does the top part of the case come off? I see a line in the casting but it does not lift off. I dont want to pound on it. I havent been able to drag the thing in out of the weather yet so have not taken it apart. Just planning ahead. Thanks Dave
