Air hammers
RBrown: If I'm at the August meeting, I'd be glad to answer any questions you have. As Ed said, get the plans for the Kinyon Air Hammer from ABANA, they answer a lot of questions.
A better result...
HW: Another thing I've done is to make a vertical display surface for things that are (normally) mounted that way, such as lantern brackets, door and cabinet pulls, hooks, etc. The vertical display surface that I use is probably about 20" wide and about 30" tall.
Rebuilding a Post Vise
Quenchcrack: I agree, if you're using a gasser that won't get to welding temp, upsetting a 5/8" rod big enough is tooooooooo much like work, and not too easy. I can't remember where I saw it, but there was an article in one of the ABANA chapter newsletters on making an 18th century garden trowel. I thought, hey, this looks neat. I about wore myself out, forging out the blade.
Hmmmmmmm........ I wouldn't say that I make a lot of hand forged nuts and bolts, but it's not at all uncommon for me to. Most recently I made some for an old cane mill in a museum, and that probably the most common reason I make them, for restorations. I can probably forge weld the collar on for the head, square up the head, drill the hole in the nut (square of course), thread the bolt, and thread the nut faster than I can drive to the hardware store.
Another possible issue with using a regular old bolt is that on some post vices (mainly older ones I think) the hole was tapered over it's entire length. An excellent set of 4 articles on making parts for post vices, written by Peter Ross and some other feller was published a few years ago in Anvil Magazine.
I can make one faster than I can find one. :D
Well, I've certainly done that with bolts before. The nuts don't work so well afterward though. :D
Boy, not me, I want a square headed, non-shiney nut and bolt on my 100 and some odd year old post vices. Actually, some of them have a round headed bolt. It looks like a rivet head.
You can use them again.
Uh, aren't we blacksmiths? We can make black bolts.
Appalachian Power Hammer
I haven't built one, but I've used one. I think you'd be better off with a home-built air hammer.
Tips on handling long stock (10 ft.)
To kind of build on what Don was saying about using the brake drum, what I would do is forge the shape of the crook portion out of something like 1/4" X 1-1/2" or 1/4" X 2", with some extra where the straight portion will be (what I'm talking about is a "J" shape). Weld this to a plate or a piece of angle iron, something you can lock in the vice, and weld a piece of round bar straight up on the short end of the "J" about an inch out so that you can lock the hook portion in it.
coal cunsumption
Is there a reason you're burning charcoal instead of soft coal? I was actully just estimating soft coal consumption for a college with a blacksmithing program that has 6 forges. I came up with 50 pounds for an 8 hour day.
shopping for a welder
We wanna learn to puddle? Get a TIG welder then. You can puddle more kinds of metal than you can with an O/A torch.
mike-hr: I don't know the answer to this, so it's not a trick question, but I've heard that the characteristics of the AC 7018 aren't the same as those of the DC 7018. I think the person that told me this was mainly talking about the ease of running a bead. Do you have any knowledge or experience with this?
anon_smith
