TJ Smith
57 -
Posts posted by TJ Smith
I Like it. Very well done.
Take care
TJ Smith
I have a photo of a 20 ton air/hyd jack press and some of the knives I have made with it. If you want them post your email.
TJ smith
Planning a building a press.
I noticed that in Jim Batson's book he specs a 2 hp motor, a 5 inch cyl, with a 5.5 gpm pump. is this gonna work? puts out 24 25 tons.
TJ
Thanks guys.
Just another idea.
I am working with a 20 ton air over hyd jack mini press . It works. But always trying to have better and faster equipment..Probably would be better if I made knives instead of equipment.
Ok where's that craigslist at.
Take Care
TJ
How about this?
What about moving a log splitter inside the shop and leaving the engine out side. Can you extend the lines long enough to work?
About 15 feet.
To cold to work outside and to much exhaust and noise to be inside.
What do you think?
TJ Smith
Yeah. need to know about this " punching guards". I sense a HOW TO coming
Try Kelly Couples for the powder.
octihunter@charter.net I think -
Thanks for all the good replies. I appreciate them.
It was a drive chain. Pre 1970 I think . No o rings. I wouldn't try a chain with o rings.
I thank Ariel Salaverria and bruce Bump for a lot of ideas.
TJ
Finished my prototype Harley Chain Knife.
It's a san-mai type construction.
Has a 15n20 core ,chain on both sides, filled with 1084 powder.
Then put in a square tube and sealed.
I used a 20 ton air/hyd jack to press the canister into a flat bar. I then ground it into a knife shape .
Here is the result.
Take Care
TJ Smith -
Yeah try a slitter first. Then take your drift and enlarge the hole. If your metal is splitting you're working it to cold. I did some spikes and had cracks. the hotter the better with spikes.
Take Care
TJ Smith
"I bought a 150# jet anvil brand new paid around $250.
It is supposed to be cast steel?? Dropped a 1 inch ball bearing from 1 foot it bounced back about 8 inches.
When you hit it with a hammer the hammer does recoil.
It will be a long time before I realize it doesn't work as good as it should. Watch out for used anvils: a lot of them have been through a fire and won't bounce a bearing at all"
Take Care
TJI posted this back in o2 wondering why a cast iron anvil isn't any good. People say good for a boat anchor or a door stop.Does anybody know why? or are we just like sheep and follow the flock? BAAAAAAAAAAAAATj -
Another version of the 20 ton bottle jack press.
Decided to try an I beam version as i have worked on some full size heavy duty press made with huge I beams.
I used a 6 inch I beam for the upright and 4 inch channel for the base. 2 piese of 4 inch channel are not strong enough and have some flex in them when under load. The beam seems to hold.
The wood being crushed is 2x2 by 3 inch long pine.
I have changed the upper bolts to 1/2 inch grade 8 and reinforced the base.
The design requires the upper anvil to be movable on the beam for other uses.
Your thoughts would welcome
Take Care
TJ -
Thanks guys for the replys.
I called clarke and there is an adapter. I have one coming. I will let you know if it works.
Take care
TJ -
I have a Clarke 180en mig welder. It has a very small tube from the gas tank to the torch. smaller than 3/16 and bigger than 1/8. Must be some metric size.
What can i do to connect gas to the regulator? How much pressure in the line from tank to torch?
Thanks for any sugestions
TJ -
Thank you guys
TJ -
New to mig welding.
How much time should I get out of a 40 C/F 75/25 tank at 20 cfh setting.
What would be a good cfh in an enclosed shop.
Thanks
TJ -
You can get beeswax on ebay
TJ
2 Hydraulic cylinders on a press
in Presses
Posted
When using 2 Hydraulic cylinders on a press, does the pressure double. If 1 puts out 10 tons does 2 then put out 20?
Thank You
TJ
