Come on guys, this should be a subject of interest to every smith on this forum. I started it to try and get us thinking and talking about flux and why we use it.
If one is welding mild steel to mild steel, one doesn't even need to use flux to weld. So why use flux at all? Well for one thing, it can be a big help. It helps overcome any problems in the fire that would interfere with the weld. Like I posted, if I'm going to have problems with a weld, it'll be when I've a audience. Using flux helps me overcome the stage fright :-) But back to the question first asked, why mix borax and boric acid together? Why use sand and borax?
For the first I have no answer, if you visit the web site of Superior flux, Superior Flux & MFG. Co. you'll find lots of different mixes of flux, all claiming the same results. Maybe it's true and one works as well as the other. So back to the start of the thread, why mix them? I not suggesting that its wrong to mix them, just I don't understand why
For the second, I have a idea and it goes back to the "Olde days" Back in the day, most smiths were using wrought iron, which with the silica already in it, didn't need flux, it was built in. So the only time one need to use flux was when welding iron to high carbon steel i.e. an axe. Sand was readily available and this is important, inexpensive. We often forget how much was done by barter back then. Hard money was hard to come by and borax would have cost money. As borax became more readily available, it started to find it's way into the shops, but still it's hard to break old habits and rather then simply use borax, it was mixed with the sand to make it go further. Remember, this is a guess. But a guess based on understanding how much was done, not because it was the best way, but because it was the best way they could afford.
So here it is Monday morning, anybody with ideas?
