The ends of links were turned from bar stock and bored for a .002" press of the bronze bushings. Used idea from this forum making up fixture when it was time to weld [aux plates with spaced holes and angled temporary bushings that align the ends of links).
couple more views as details were mocked up
The bearing hub is mounted on a really heavy angle (1-1/8" section) that was bored and then drilled on Kearney Trecker Rotary D
The wheel is "permanently" mounted...without cutting the center crank pin plate off the wheel there is no getting at the lugs, so they are torqued tight with impact wrench. The crank plate/center section is approx 1" thick and has a turned crank pin 1" diameter. the crank pin is pressed into a through drilled hole and welded to the 1" thick disc which is itself welded to the wheel...tried to be careful to get it "square". WHY? well that is the spare I had that fit the bearing hub...I wanted the "overhang to be minimal" so I mounted same way as it mounts on the vehicle and this solution used pieces I had and so appealed to me. Making another wheel/crank pin would be pretty quick..getting this one apart not so quick but its a design trade off I made and will live with. The counterweight is something I am still noodling on.
