I would feed the 1" in the left side rotating 90 degrees each blow, the right side is to smooth and straighten it out. Has anyone tried a swage like this? It is going to be a little bit of a pain to forge or I may get it CNC cut. If someone has tried it and it was a complete disaster I won't bother.
Fuller Swage
#1
Posted 14 March 2010 - 01:04 AM
#2
Posted 14 March 2010 - 03:51 AM
#3
Posted 14 March 2010 - 10:31 AM
I got rid of my metal lathe in favour of keeping a second hammer, I had no space for both. It was a beat up really old South bend anyways, I had no change gears and it would not take any sort of heavy cut. So I think I may forge the master rather than turn it. What I am thinking is use a spring fuller to rough it down , then use a larger radius spring fuller and a kiss block to finish it. Even if this ends up a little rough rotating it and taking light blows while finishing the swage should make it reasonably smooth. If the concept works but the swage is too rough or if I get too busy and need the die I may just get it cut on a cnc mill, I would think they could cut the two sides out in an hour or so. Thats much faster than I could make the master, forge the swage and then relieve the edges, and then forge or drill out and relieve the finishing swage.
#4
Posted 14 March 2010 - 10:42 AM
#5
Posted 14 March 2010 - 11:17 AM
#6
Posted 14 March 2010 - 11:59 AM
Would it still work if the "fullers" on the left section could be roated through 90o It might be a relatively easier shape to make using an angle grinder and dynabrade belt sander.
Its all about putting the FUN back in dysfunctional.
Captain Psychobabble
#7
Posted 14 March 2010 - 12:00 PM
southshoresmith, on 14 March 2010 - 10:42 AM, said:
I second, third and fourth that.
#8
Posted 14 March 2010 - 04:01 PM
#9
Posted 14 March 2010 - 05:17 PM
southshoresmith, on 14 March 2010 - 04:01 PM, said:
With the big hammer I am making them faster than I ever have and if this swage works as planned it may take a while to pay off but I am always looking for a quicker way to do things.
#10
Posted 14 March 2010 - 08:29 PM
#11
Posted 14 March 2010 - 09:29 PM
This is what I made last summer. Goes from 1" down to 1/2". I use is mostly to "true up" a length.
All I did was take a piece of flange cut off from a beam at work, drill the holes, radius the edges a little, weld on a U shaped piece of 2"X1/4" flat bar, then cut it down the middle on the saw. Clean the cut edges and done. Added the piece for a hardie mount so it stays on my anvil.
#12
Posted 14 March 2010 - 09:34 PM
Be nice to do it in a pair of dies, 2X faster than a swage.
but then there are others who, with the help of their art and their intelligence,
transform a yellow spot into the sun.” ~ Pablo Picasso ~
#13
Posted 14 March 2010 - 11:14 PM
#14
Posted 15 March 2010 - 02:38 AM
JNewman, on 14 March 2010 - 11:14 PM, said:
You know, real dovetailed dies to go in your hammer.
#15
Posted 15 March 2010 - 05:32 AM
Nakedanvil - Grant Sarver, on 15 March 2010 - 02:38 AM, said:
Kinyon's don't have anywhere near the ooomph of a Massey and bolt on dies aren't really the thing for production work ...... BUT that said it is so convenient being able to knock up a couple of speciality dies without the hassle of machining tapers. I've got a bridgeport -ish mill and it's still hassle to set up to machine them (maybe ok doing batches).
I'm a total fan of using speciality dies rather than spring swages. I didn't realise they forged quicker because I've never compared them to the same work done with a spring swage. I like them because they don't bounce around so much and you often end up trying to steady the swages with one hand. I've got two Kinyons types and an Anyang 40kg so on a job it's geat having 3 hammers some of which have speciality dies and being able to flit from hammer to hammer in one heat. The Anyang moves the meat of the work and the Kinyons do the "shaping"
How long a run are you doing? Might be work making some special dies that you can fit bolt on dies to for small production runs or testing out protypes or evolving the optimum die faces and general experimenting. When you've sussed it you could then go to the expense of making proper dies. The other advantage of fabricated dies is cost, you don't need so big a chunk of alloy steel, useful if you're just experimenting and might have to try a few different options. I usually forge/machine/grind the "business end" out of a small piece of EN24T (4340???) and weld it to a mild steel base. I've got speciality stainless steel welding rods for welding mixed metals, can't remember the grade but can find out. That said most time these days I just mig weld it together. Holds out pretty well for the small scale and batches of work I do.
#16
Posted 15 March 2010 - 10:08 AM
Then again I`ve been known to repair CI with 7024(when no nickle rod was available) and have it hold long term.
#17
Posted 15 March 2010 - 10:23 AM
Yeah 309 rings abell. I've got some 312 and 309 rods but I can't remember which I used, whatever one it was, it stands up pretty good. My
You just can't beat "needs must" when running a small workshop!
#18
Posted 15 March 2010 - 01:03 PM
#19
Posted 15 March 2010 - 01:11 PM
southshoresmith, on 15 March 2010 - 01:03 PM, said:
Yeah, the flow of metal can sometimes puzzles me and there are sometimes i end up squeezing rods of plasticene to try and get a hook on things.
.....could do with some S.T.O.C.K. flavouring to the more esoteric aspects of metal flow.
#20
Posted 15 March 2010 - 03:49 PM
Dennis you should relieve the sharp corners more on the holes so you don't get marks on your steel. The bottom 45 degrees is the part doing the work. The steel squeezes out the sides and if there is a sharp corner it can cause cold shuts.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
