January 13, 200917 yr Having trouble being efficient with long tapers in 1/2" round stock. Should I fuller the whole length first and then forge to square/octagon/round or work on one section at a time? Also, should I fuller on all 4 sides or just the top/bottom of the round? Thx, Keith
January 13, 200917 yr Start at the tip. Set up a square point. Work your flats back from the tip going to square. Do it in sections; don't try to heat 12" of stock and forge a taper. Keep your taper smooth as you go; watch for steps and thick spots. Get your taper set and then yes, go from square to octagon back to round. Remember, you don't need 12" of stock to forge a 12" taper... it'll grow on you. Compensate for that up fromt. Good luck, Don Edited January 13, 200917 yr by Don A
January 13, 200917 yr look at this blue print BP1021 Forging long points bet it will help it is with a power hammer but the process is the same with a hand hammer Edited January 13, 200917 yr by phil shelton
