jersey_beginner Posted June 3, 2023 Share Posted June 3, 2023 Hey all — I'm new here and am hoping to find some guidance on identifying this forged anvil I recently purchased for home use. (Also, suggestions for cleaning it are welcomed.) Here are some photos depicting the clearest identifying marks. I'm guessing it's English (based off the flat base and bottom), and maybe weighs 126 pounds (if I'm reading the weight marks correctly)? The base under the horn is stamped with what looks like "LB," with some other lettering, or maybe numbering, underneath the "B." It has good rebound and makes a sharp "ting" when the face is struck. What do you think? I can upload photos of the other side, if that's helpful. There may be a "1" marked in the middle on the other side, though it's hard to tell. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 3, 2023 Share Posted June 3, 2023 Welcome from the Ozark mountains. Cleaning is easy using a cupped wire wheel on an angle grinder, then a coat of BLO (boiled linseed oil) will protect it. Also some folks use electrolysis which is very effective in removing rust. Pictures of the other side, the underside of the base and heel will also help. Knowing where you and it are located will also help. Speaking of angle grinders hope you have read about not doing any grinding, milling or welding on the hardened steel face, which does more harm than good. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
jersey_beginner Posted June 3, 2023 Author Share Posted June 3, 2023 (edited) I appreciate your help. Glad that linseed oil and a wire wheel is the way to go - the simplest cleaning techniques are often the best. Will definitely avoid damaging the face (which is still in good condition). I've attached photos of every side. I'm located in NJ and bought it from someone in Bucks County, PA. They didn't know anything about it, except that their husband purchased it about four years ago and that they didn't want it in their garage anymore. Would love to know what you all think about its possible age, origin, and, ideally, manufacturer. Edited June 3, 2023 by Mod30 Remove @name tag Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 3, 2023 Share Posted June 3, 2023 This is a guess but I think it is an early Vulcan, imported from England by the Illinois Iron & Bolt Co. usually with II&B cast into them. A shame that a blacksmith used the area where the English Hundred Weight is stamped. If the center number is a 1 it weighed 154 pounds when made. Best way to check is to put it on a bathroom scale to confirm the weight. If the center number was a 0 it weighed 126 pounds. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
jersey_beginner Posted June 4, 2023 Author Share Posted June 4, 2023 Interesting. That could explain the "IB" cast onto the base underneath the horn. Do you know if there's any way I could confirm, or at least look into, that theory? I'm going to clean it up soon and look for additional identifying marks. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 4, 2023 Share Posted June 4, 2023 The best way is to get a copy of Anvils in America. To buy one it's kinda costly, but if you have a library near you they might have a copy or can get it for you through the ILL (interlibrary loan). Google might help search for early vulcan anvils imported from england. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
jersey_beginner Posted June 5, 2023 Author Share Posted June 5, 2023 That's super helpful - thank you! I'll clean it and request a copy of the book. If I can get a good identification, I'll update this post for everyone. I'm grateful for the help! Quote Link to comment Share on other sites More sharing options...
jersey_beginner Posted June 19, 2023 Author Share Posted June 19, 2023 Hi all – A quick update. After cleaning the anvil and reading Postman's book, I was able to successfully identify it. Someone had painted the sides with white lead paint and then someone put a second coat of black paint on top of that, so the maker's mark was obscured. The anvil is a Hill! It was made by Isaac Hill in Birmingham, England probably between 1830-50. It weighs more than I had thought, clocking in at 179 lbs on the scale. The mark under the horn must have been made by an inspector. So glad to have found this beauty! Quote Link to comment Share on other sites More sharing options...
