CrazyOatmeal Posted May 29, 2023 Share Posted May 29, 2023 I have a heap of coal coke mixed with slag, nails and rubble. I want to end up only with coke. I'd like to avoid the suicidal mundanity of picking every single individual piece of coal coke out of the heap. All soluble matter has been dissolved, all bouyant matter has been skimmed, all contaminants less than 1cm or greater than 5cm in diameter have been screened. What should my next step be? Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 29, 2023 Share Posted May 29, 2023 I think that you have done about all you can do except use a magnet to extract any ferrous metal. I once had a load of coke that had about 15% rock in it and I had to pick it out piece by piece from each shovel full I put into the forge. The only way I could think of to separate it would be a heavy brine flotation process to get the lighter coke to float and the rock to sink but that seemed to be more hassle than hand sorting in each shovel full. I thought about saving all the rock and taking it back to my supplier and demanding an equivalent weight of coke. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
