tecnovist Posted August 12, 2008 Share Posted August 12, 2008 Stress Releave Springs Hi all --- I need to build some springs to repair a car lock -- I under stand if I use a spring and re form / bend it to the required shape to make the new spring, I need to stress releave it --- Some spring will be Stainless Springs and some Spring Steel --- Can any one tell me some different technics of doing this, and the temperature's needed to achieve this ---Thanks could I melt some lead and put the reformed spring onto the molten lead -- what ease ways are there of telling the temperature of the lead--- Quote Link to comment Share on other sites More sharing options...
tecnovist Posted August 13, 2008 Author Share Posted August 13, 2008 FAQs about Blacksmithing and Metalworking (This sounds good) A primitive method is to use a small pine stick and see when it chars in the melt. . . I think this is 450 to 500 F. A more accurate but primitive method is to make a bunch of polished plain carbon steel "coupons". You hold half of one of these in the melt with light tongs and watch the temper colors. When the colors stop changing it is at the melt temperature. Compare the temper colors to a temper color chart similar to the one we have in our FAQs. This will give you fairly accurate readings from 420 to 640 F. Quote Link to comment Share on other sites More sharing options...
