November 27, 20205 yr some time ago I made this support and I must say that I find it very convenient and useful. it is assembled and disassembled in few seconds and allows you to fix the grinder to the vice and work by holding the piece with two hands. so it is possible to be much more precise especially if you work on small pieces. you can mount all the discs and use the tool to grind, cut, wire-brush, smooth, sharpen, polish, sandpaper, remove rust, strip paint, etc. etc. in addition it allows to hold the grinder in the vice in many positions here you can find the video and inside there are all the details and mesurements if someone wants to build it: https://www.youtube.com/watch?v=uAuiQPC4EwY
