Okiepan Posted February 23, 2020 Share Posted February 23, 2020 I just acquired a champion forge , the blower has no markings on it , the pan has a 145-3 stamped on the bottom of it , It is all intact and works , a little rusty on the 3 legs . Any information on this would be greatly appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 23, 2020 Share Posted February 23, 2020 Pictures of your forge will help. Is the pan cast iron? If so have you clayed it to keep the cast iron from cracking? Quote Link to comment Share on other sites More sharing options...
Okiepan Posted February 24, 2020 Author Share Posted February 24, 2020 This is the forge I was asking about . Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 24, 2020 Share Posted February 24, 2020 I just found my PDF copy of the Champion Blower and Forge catalog #52. On page 29 there is a 145-S three leg forge. You might have a look to see if it's like yours. I just saw your reply with picture, it looks like the 145-S to me. The pan is heavy gauge pressed steel so probably won't need clay. https://ia803102.us.archive.org/21/items/championblowerandforgecocatalogno521926/Champion Blower and Forge Co Catalog No 52 1926.pdf Quote Link to comment Share on other sites More sharing options...
Okiepan Posted February 24, 2020 Author Share Posted February 24, 2020 Any idea how old it is ? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 24, 2020 Share Posted February 24, 2020 I think the catalog was from 1926, so the forge is probably from around that time period. Also the blower on those forges was/is a #140, which were not marked like the #40 or #400. If it were mine, I would replace the makeshift fire grate. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 24, 2020 Share Posted February 24, 2020 I suggest taking the gear cover off and checking the gears and condition of the oil, which is probably a hardened mess. I don't recommend taking the blower apart because there are no parts available if something breaks. Just wash the old oil out with some kerosene or diesel fuel. Then add oil (I use 80 wt gear oil) but any oil will do. Do not fill the gear box with oil because it will leak out. Use just enough for the lower gear to run in oil which will then oil all the other gears & bearings. It's a splash system of oiling. Quote Link to comment Share on other sites More sharing options...
