German sacrificial deposits from the swamps of Jutland
Asymmetrical spear with central ribs and hexagonal sleeve.
Forged based on finds from Nydam, Jutland. Length 45 cm, width 4.5 cm, hole 1.9 cm, weight 445 grams.
Knife, 28.5 cm, walnut handle, leather sheath, bone tip. Length in sheath 30 cm (Illerup Adal, Nydam) Spear, length 37.5 cm, width 3.5 cm, hole 1.9 cm, weight 210 grams,hexagonal sleeve (Illerup Adal) Ax, iron welded, length 16.5 cm, hole 3.5 cm X3 cm, weight 450 grams (Nydam).
Ax plus spear, . Welded ax, length 17.5 cm, hole 3 cm, blade width 6 cm, profiled blade eight wall, weight 540 grams. Spear, length 31 cm, hole 19 mm, width 3.7 cm, weight 220 grams.
Iron Age (Illerup Adal) set.
