August 28, 20178 yr Some while back I was given a pair of bench shears with a chip knocked out of the edge of one blade. I would like to have them repaired but I don't know how to go about it. How do I determine the alloy of the steel edge? It seems that would be the starting point, before I go on to welding and heat treating. The edge looks like it is welded to a softer iron body and I don't know how that affects heat treat. Thanks in advance for considering my questions
September 4, 20178 yr Can't tell from the picture but it looks like that chip is not that bad and I would draw file the cutting edge to get it out. I have a pair like those and have sharpened them without any problems.
September 6, 20178 yr Author Irondragon, thanks for the reply I think there is enough steel in the edge of the blade to grind or file, but I'm concerned that changing the profile of the edge might do more harm than good. I haven't taken a file to it so I don't know how much of a job that would be. If I were to grind or file and ended up with the tip unable to close, I presume I could bend the handle to correct that. I don't know the alloy of the handle or whether it is heat treated, as in spring, so the question becomes what about the heat affected zone from the bend. I will go get some better pics with scale. maybe you or someone else can give me more guidance If it can be seen better.
September 6, 20178 yr Author here are some new pics. I lightly filed the edge and sanded the face of the blade. you can see what I believe is the line between steel and iron in the 5th picture
