SteveW Posted August 12, 2014 Share Posted August 12, 2014 Long story short, I have a new forge to play with. It's a bottom blast and I'm wondering if anything is missing from the fire pit? I have only used side blast forges so far, and cant help thinking some kind of diffuser or grill should be over the air hole. with luck there should be some pictures here to show what we have at the moment. many thanks Steve. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted August 12, 2014 Share Posted August 12, 2014 It's correct as pictured. I always position my clinker breaker in the "down" position when running a fire and rotate it to the "up" position to lift clinker and clear cinders from the hole. Quote Link to comment Share on other sites More sharing options...
SteveW Posted August 14, 2014 Author Share Posted August 14, 2014 Hi, thanks for the information:) I need to get that hole covered with a bit of plate, start a small fire to make sure the chimney is drawing ok then its time to get some coke in her and see if all works as it should Thanks again for the help Quote Link to comment Share on other sites More sharing options...
