My first build of a propane tank gas forge.
So, here is my first build of a propane tank gas forge in progress.  Legs are 1.5" steel flats bent to shape and bolted on.  Burner is a hand built modified side arm burner per Zoeller Forge design.  Front lid is cut off and bolted on with a hinge.  Just need a few more brass fittings for the idle circuit, and the Cerawool lining.
1623478_10203952846610058_85654315453346
10446504_10203952846970067_3835109364869
994101_10202626673936570_2039697914_n.jp
