March 30, 201412 yr On my shop built Hossfeld bender. Note that it drops into the table in 2" square "goesintas" (Frosty) My vises, hand roller, and B-3 shear also fit the goesintas. The vises are mounted on a plate with a 2" round bar stub so the can swivel. Under the 1" thick table a trailer hitch receiver is welded directly under a 2" square hole in each corner of the table. Things I don't want to rotate I mount on solid 2" square bar or 2x2 x1/4" tube steel if it is a light duty tool. This makes it quick and easy to mount a vise or a tool or clear off the table for a big layout. I needed ten rings and bent then in less than 10 minutes including setup.
