BobL Posted March 2, 2014 Share Posted March 2, 2014 Here's a simple mod to a small bench grinder based linisher I thought you guys might like to see. The top roller (comes from an Aussie wood working sanding accessory to a drill press ) is spring loaded and provides the necessary tension. The roller is are chain clamped to a metal pipe which is itself bolted to a vertical piece of HD Unistrut. The pipe position can be moved up and down the Unistrut to accommodate different length belts (shown is a 48" belt). Belt tracking is handled by the front roller of the linisher. Quote Link to comment Share on other sites More sharing options...
Willis Posted March 2, 2014 Share Posted March 2, 2014 Great idea. I like this Quote Link to comment Share on other sites More sharing options...
