Don A Posted July 12, 2007 Share Posted July 12, 2007 Based on one of my earlier posts, I would really appreciate it if any and all would elaborate on techniques for forging a uniform right-angle. Let's say 1/2" or 5/8" square stock in a coal forge only; no torch.Always seems to be more than one way to skin a cat. Don Quote Link to comment Share on other sites More sharing options...
Acier Posted July 12, 2007 Share Posted July 12, 2007 Not sure if this is what you are after but have you seen in part 5 of the Blacksmiths craft book download here:The Blacksmiths Craft Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted July 12, 2007 Share Posted July 12, 2007 There are a couple ways to do this. I actually prefer to do a glut weld by cutting the stock partway through and bending hot to get a sharp inside corner then sticking a piece in the remaining void and forge welding it to make the outside corner. I started using this method because I find it to be less work, more accurate and faster. The other, more traditional way is to bend as normal and start upsetting in two different directions so each leg pushes material into the outside corner. You don't work on the corner as much as working on the legs to get the material to upset. Hope this makes sense. Quote Link to comment Share on other sites More sharing options...
Strine Posted July 12, 2007 Share Posted July 12, 2007 With no time to explain anything it is a matter of making about a 70d bend and upsetting in the vicinity of this bend to fill out the radius gradually increasing the angle to 90d. There's a bit on it herehttp://www.iforgeiron.com/blueprints-200-300/bp0295-nail-in-hooks.html Quote Link to comment Share on other sites More sharing options...
Don A Posted July 13, 2007 Author Share Posted July 13, 2007 Many thanks gents. That's what I needed. Don Quote Link to comment Share on other sites More sharing options...
