bound201 Posted March 7, 2013 Share Posted March 7, 2013 I'm currently using propane for my forge but I'm considering building a blown burner natural gas forge. I know I need to consider a pressure switch to cut off the fuel supply in case of the blower stopping. I've read some people not using an orifice for natural gas due to the low pressure that is run into homes but I've also read where some did. Is there a size you'd recommend for a 3/4" or 1" burner? I realize I need a way to adjust the fuel through a valve to fine tune things but just curious about a starting point. This will be using home natural gas line so it will be low pressure. Quote Link to comment Share on other sites More sharing options...
