June 27, 201214 yr I had at one time a copy of the Apple Mac Hypercard Stack that contained the Samuel Yellin job cards. I think that this was created by Jack Andrews for his book, Samuel Yellin: Metalworker since he talks about it in the book and has a summary of some of the information. I have hit a dead end trying to get contact info for Jack. Skipjack press seems to have been sold at least once and Google has not helped me so far. Does anyone have a copy of the Hypercard stack and/or current contact info for Jack Andrews that they would share? Thanks, Doug
June 28, 201214 yr Please forgive my ignorance but what is the hypercard stack? Sounds useful if from yellins records.
June 28, 201214 yr Author Hypercard was an application provided with Apple Macintosh systems from 1984 through 2004. It was a simple to use user interface builder/database. It was not continued when the Macintosh moved to their new OS X operating system. My intent is to port the Yellin job cards into some system that more modern computers can run and make it available on iForge. - Doug
July 2, 201214 yr I may have it, if you know what disks it on. I should have several system 9 disks around, just have to find them and see what is there. Is that helpful?
July 2, 201214 yr Author Thanks for the offer. Unfortunately, the stack with the Yellin job cards was not distributed with the system by Apple. It was a separate stack put together by Jack Andrews for his book. - Doug
July 5, 201214 yr http://download.cnet.com/Apple-HyperCard/3000-2247_4-342.html Edit - Never mind, I thought it was just the program you were after. On a side not RunRev have a product called livecode which works on most OS and allows you to import hypercard stacks.
July 5, 201214 yr ....Skipjack press seems to have been sold at least once and Google has not helped me so far. Skipjack Press is one of the companies that was purchased by Kinney http://www.finney-hobar.com/skipjack.htm
July 6, 201214 yr Author Thanks for the pointers. I have had an email in to Finney for a week now with no response. I'll have a look at LiveCode. I had not heard of that product before. I was planning to use SuperCard but that is a fairly expensive product so it would be nice to have an alternative. I do have a couple of leads from other sources that I am chasing. If I finally make contact, I'll let folks here know. Thanks - Doug
July 6, 201214 yr http://louie.cs.nott.ac.uk/pmm/space/Hypercard%2Bclones I found this list if clones while poking about, might be of some use to you.
December 5, 201213 yr Did you ever find a contact for Jack Andrews? I'm a former student and coworker of his from Yellin who is trying to email him. Thank you. Chris
