Karn3 Posted May 22, 2011 Share Posted May 22, 2011 I currently have a solid fuel fire, and it's great. I can do everything in it, but I have decided to move into more of the blade smithing side of things and would like to get/make a propane forge for all the fire welding (cleaner fire etc.). I've done some searches on the and found many designs and tutorials for making a gas forge. Being relatively inexperienced with them though I can't tell what is a good design and what isn't. I was wondering if any of you knowledgeable people could perhaps steer in the right direction. I will start with knives and hopefully move onto swords, so if I can build something that will be suitable for both that would be excellent. If not that's fine I'll just build two . Any hints, tips, and links will be greatly appreciated. When I start building it I'll upload some pics so you can see how I'm doing. Quote Link to comment Share on other sites More sharing options...
Silverker Posted May 24, 2011 Share Posted May 24, 2011 Karn3- I'm kinda of in the same boat, but different reasons. Here we have a problem with burn bans (one just lifted after about 45 days) which means I can't always fire the old coal forge up. So I was thinking about a gas one as well, because we can use propane during the bans. Like you, I have also found enough information that I get kinda of confused on which way to go. Thanks for a post that will help me and probably others. Quote Link to comment Share on other sites More sharing options...
jcornell Posted June 21, 2011 Share Posted June 21, 2011 I currently have a solid fuel fire, and it's great. I can do everything in it, but I have decided to move into more of the blade smithing side of things and would like to get/make a propane forge for all the fire welding (cleaner fire etc.). I've done some searches on the and found many designs and tutorials for making a gas forge. Being relatively inexperienced with them though I can't tell what is a good design and what isn't. I was wondering if any of you knowledgeable people could perhaps steer in the right direction. I will start with knives and hopefully move onto swords, so if I can build something that will be suitable for both that would be excellent. If not that's fine I'll just build two . Any hints, tips, and links will be greatly appreciated. When I start building it I'll upload some pics so you can see how I'm doing. Check out Larry Zoeller's very good site: http://www.zoellerforge.com/simplegasforge.html and http://www.zoellerforge.com/firebrickforge2.html My gas forge resembles the firebrick forge, except that I've not used the steel frame on the outside, relying on the mortar to hold everything together. Quote Link to comment Share on other sites More sharing options...
