shoer Posted February 2, 2011 Share Posted February 2, 2011 A few weeks ago I got a Hay Budden in decent shape. The current issue is that the hardy hole - when viewed from above - is actually twisted as it goes through the heel. A hardy shank can go in from the top about 1/2 inch and from the bottom a bit more than an inch. Is there a reasonable way to square the hardy hole up or some other work around that will make it usable? Quote Link to comment Share on other sites More sharing options...
its512eric Posted February 2, 2011 Share Posted February 2, 2011 plop it down in front of the TV, get a file and pick two corners that are the most square and bring the other to meet them. sunday when the game is on would be a good time, as you can rewind if you miss something exciting it took me about an hour a corner to square up my kohlswa Quote Link to comment Share on other sites More sharing options...
joshua.M Posted February 2, 2011 Share Posted February 2, 2011 plop it down in front of the TV, get a file and pick two corners that are the most square and bring the other to meet them. sunday when the game is on would be a good time, as you can rewind if you miss something exciting it took me about an hour a corner to square up my kohlswa what type of kohlswa is it? Quote Link to comment Share on other sites More sharing options...
its512eric Posted February 2, 2011 Share Posted February 2, 2011 what type of kohlswa is it? english pattern ruffly 78lb (not the 80's soft steel) and now have a 7/8" hardy hole instead of 3/4" Quote Link to comment Share on other sites More sharing options...
joshua.M Posted February 2, 2011 Share Posted February 2, 2011 english pattern ruffly 78lb (not the 80's soft steel) and now have a 7/8" hardy hole instead of 3/4" oh ok iv been looking for a b-38 south german wide face Quote Link to comment Share on other sites More sharing options...
