January 20, 201115 yr This is my first set of tongs, actually its my first anything smithing. It took some work, especially with a very makeshift forge(firebrick and propane burner from a deep fryer). I started out with two lengths of 1/4 x 3/4 x 14" flat stock. Total length at completion was around 19". I had some issues forming the tabs on the end(i had to crease them in the corner of the table and face of the anvil, didn't come out too well). I think i should have squared up the end of the bend by the tabs for more clearance instead of just leaving it flat.
January 20, 201115 yr Looking darn good for a first set of tongs, nevermind a first time smithing! My first set of tongs will never be photographed, and my first attempt at forging shouldn't even be mentionned. Keep up the good work!
January 20, 201115 yr Yes they do look great for a first forging project. Now you have a set to work with to make more. Good job. :D
January 20, 201115 yr Author thanks. I'll have to admit, it was my second piece, the first being a 2" bolt I ran out and flattened, . I also watched a video on youtube. Boy was i suprised when i started drawing out the 1/4 x 3/4 stock to square, hand cramps anyone. Can't wait until the forge is actually finished so i can get some solid heat on this stuff(looking at color charts it appears I'm working my metal at around 1600-1700F). I'm working on a new hardy right now, started out with a piece of 1x1x3, tapered it to around 3/4 for hardy hole, heated and have since beaten it to about 3/4" tall and about 2" square(square being a very generous term in this case), just not sure what I'm going to do with it from there, either a swage or maybe a fuller, since I got hammer happy and flattened it too much for a hot cut or horn/shelf.
