Tryingtoforge Posted September 15, 2006 Share Posted September 15, 2006 Hello, I a new to the forum & trying to learn as much as I can. I am building an LP forge. How does the Ceremic Fiber Insulation stick to the steel walls? do I use a bonding agent? Also how to bond the ITC-100 to the steel walls. I wanted to coat the steel interior first with ITC-100 & then line it with the insulation. I would then coat the insulation with ITC-100. For the floor, I want to place the insulation & ITC-100 then top it with ceremic tile. Is this ok to do or is their a better way. Any help would be appreciated. Best Regards, Ed Quote Link to comment Share on other sites More sharing options...
pjskinner Posted September 15, 2006 Share Posted September 15, 2006 Are you building a cylidrical forge And is it for welding? If so The ceramic insulation is pretty ridged stuff so it needs no support to hold it up. About the Itc-100 I wouldent waste it by putting it on the steel "put it on the insulation". About the ceramic tile I really see no need for it unless you are applying Flux for forge welding then it would be a good idea because: hot flux+ceramic insulation= eventually no insulation..... "the stuff eats it like crazy!" Hope this helps, Pj P.s. If you need any ideas theres bukoo websites including a B.P. on the web http://www.iforgeiron.com/Blueprints_200-300/p2_articleid/223 Look at gos forges at the bottom of the page. Quote Link to comment Share on other sites More sharing options...
