antigoth24 Posted December 29, 2009 Share Posted December 29, 2009 firstly a happy new year to everyone! and secondly i love to recycle and am just starting into knives...so i had a couple old jack hammer bits lying around so i took of about 3.5 inches of the end and made a fairly large knife. but as it says in the title everything on this knife was essentially "recycled"...the handle is made from an old maple plant hanger someone was throwing out, jack hammer bit is self explanatory, the hand guard was made from a spoon, and the leather from a broken sling (swing around your head kind). overall i was fairly pleased with the knife except for a couple things...this was the first time i tried the "drill and burn" technique for a solid handle and i drilled just a little off so the blade is slighty crooked but i have no more of that maple so i went with it and figured it would be a good reminder for me later...and then the over thing was these kind of curvy lines that showed up in a few spots after quenching (are they stress marks?) well anywho this is my second knife and please let me know what you think...thanks guys! pics arent uploading properly so ill trying posting them again. Quote Link to comment Share on other sites More sharing options...
antigoth24 Posted December 29, 2009 Author Share Posted December 29, 2009 ok so its still not letting me upload but here are some links to it...To attach photos on the new system, click on use full editor next at the bottom of this text box. click on the button click to attach files and browse your hard drive for the file. Highlight the file and click open. Repeat as needed for additional files. Click the box click modified post to save. Quote Link to comment Share on other sites More sharing options...
SBuzek Posted January 1, 2010 Share Posted January 1, 2010 Looks like cracks,maybe overheated before quench,or maybe you quenched in water and it cracked. Stan Quote Link to comment Share on other sites More sharing options...
antigoth24 Posted January 1, 2010 Author Share Posted January 1, 2010 Looks like cracks,maybe overheated before quench,or maybe you quenched in water and it cracked. Stan kk thanks im still learning the basics with knife making so i probably did overheat it before quench Quote Link to comment Share on other sites More sharing options...
jarguello Posted January 2, 2010 Share Posted January 2, 2010 kk thanks im still learning the basics with knife making so i probably did overheat it before quench Remember a magnet is your friend, heat until a magnet wont stick to the blade anymore, heat just a bit more and then quench. Hope this helps. Joe Quote Link to comment Share on other sites More sharing options...
