December 23, 200916 yr Having only two hands, I finally stopped and made some veining tools. One is for the center vein and the other for the laterals. The lateral tool uses a 3/4" bolt for the anvil and can be swapped out for different shapes. I didn't have any tool steel the size that I needed so I turned down a cheap chisel on the lathe.
December 23, 200916 yr Keith, Oh yeah, those are nice. great job! - Would you mind considering those ideas stolen?
December 23, 200916 yr With a little modification you could turn that one on the right into a blood groove fuller. Turn the top fuller ninety degrees, add another to the bottom and add a spring, then you got one(I think). Any way, nice job.
