Variable speed blower
I got my variable speed blower for my coal forge done It's a sewing machine motor attached to a small cooling fan. It works great! The only complaint I have is that the pedal slides around alot. I'll have to fix that.
19088.attach
19089.attach
Thats great, it reminds me of a forge my wife owned, that was portable and a treadle mechanism like that off of a singer sewing machine operated the attached blower.
Nice one :)
probably the best idea i have seen yet for a variable speed setup thank you for sharing.
  • 2 weeks later...
Great idea for controlling the speed! Here's another idea: In my woodworking catalog they sell a variable speed router control. Basically, you plug it into the wall and then plug your motor into the control. The speed is controlled by a knob. It would free you up to move around the shop while you're waiting for your heat.
He could forge a clip that would hold the motor on some when needed. He could also then mount the switch on the same leg as the motor and reach it with his hand.
