RichHallstrom Posted November 1, 2009 Share Posted November 1, 2009 I just bought a buffalo forge hand cranked blower. The guy who sold it said he took it apart and cleaned it and that the crank case needed oil. I have been told to use anything from 10w oil with a little kerosene to 90w gear oil. What is the proper oil to use? I'm leaning towards the gear oil, but I could be wrong....it has happened before. Thanks.. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted November 1, 2009 Share Posted November 1, 2009 I use plain old ATF. The heavier gear oils just make it harder to crank - especially when the weather is cold. Some designs have gear sets that run in oil while others just take a periodic squirt. Quote Link to comment Share on other sites More sharing options...
JeremyP Posted November 2, 2009 Share Posted November 2, 2009 I put ATF in my champion hand blower but the oil slowly seeps from between the case so Im thinking I might lube it with some lubriplate assembly grease instead Quote Link to comment Share on other sites More sharing options...
anvillain Posted November 2, 2009 Share Posted November 2, 2009 I have a champion 400 and a small rivet forge. Both are well worn and a little noisy in the gears. I use chain saw "bar and chain oil". It is designed to stay on a high speed chain. There are summer and winter grades. Use the winter grade as it is not so heavy. It quiets down those old gears very well. What ever you use, just don't run them dry. Anvillain Quote Link to comment Share on other sites More sharing options...
jmeineke Posted November 2, 2009 Share Posted November 2, 2009 Thanks for asking the question, Rich. I wondered the same thing myself. I just purchased a Champion 400. I put some white lithium grease on the gears (mainly because that's what I had lying around). I haven't tried putting anything else in there just yet. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted November 2, 2009 Share Posted November 2, 2009 Phillips Petrolium makes many grades of oil. I use "MM" grade 30 wt. in the crank blower. I think 10 wt would be fine. This is non detergent oil. I have I must admit over the years added some seafoam or Marvel Mystery oil. This is in a Canedy Otto blower for the trailer shop. Quote Link to comment Share on other sites More sharing options...
RichHallstrom Posted November 3, 2009 Author Share Posted November 3, 2009 Sounds like light oil is easier to crank. I might go with that since winter is here. As long as it has something to lubricate the gears it should be OK. Thanks. Quote Link to comment Share on other sites More sharing options...
