andgott Posted April 8, 2009 Share Posted April 8, 2009 I had fun with this one! The bowl is forged from 1/8" steel plate, freeformed on the anvil & a swage block. It is about 5" in diameter. The base is 4 pieces of 3/8" round, drawn & tapered then forge welded together. I 'bundled' the parts together using Brian Brazeals method- It makes for an INCREDIBLY easy forge weld. I am not sure if I am done with the bowl or not- I might do a light acid etch to clean it up a bit more before I clear coat it, but I kind of like the texture that it has now. Quote Link to comment Share on other sites More sharing options...
Dodge Posted April 8, 2009 Share Posted April 8, 2009 Neat! I like it! Very Medieval/Tolkienish :D Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted April 8, 2009 Share Posted April 8, 2009 Nice looking bowl. What are you going to put in it, nuts?:D Quote Link to comment Share on other sites More sharing options...
andgott Posted April 9, 2009 Author Share Posted April 9, 2009 Thanks... I ended up cleaning the bowl up a bit more with Vinegar, and giving it a light bufffing with fine steel wool... I'll post pics later. Off to the shop again this afternoon! -Andrew Quote Link to comment Share on other sites More sharing options...
