trattoclip
  1. Hi Minotaur ! thank so much ! I had found nothing ! [email protected] it's my mail please send me an confirm (with PM) when you send the mail Fantastic ! thank you very much for your help ! :)
  2. My friend buy this hammer form a school, very very in a good condition, but need the complete manual for this hammer. I search into this forum and on the web but I found nothing ! Can you halp me for this problem ? Thank you very much ! Have a nice days !
  3. I have an anyang hammer, very good product ! I work until 40 mm x 40 mm square, without a problem ! now I use this hammer for damascus billet
  4. Hello to all, with much displeasure I must abandon l' activity of blacksmith. cause familiar, serious reasons now I will sell all this that I have in order to gain money for other essential plans I will sell all ! This not a mechandising message... If you interested, contact me with PM I must sell all, I have need of money in order to face the adversities power hammer c41-15 (used only 15 hours) perfeclty restored, I have replaced the not perfect parts with made new of European materials I have a image to cinfirm this !) concrete and steel base hammers hofi hammer 1.3 kg, used less hours c 45 steel for tool many many chiesel a good gas forge t-rex burner etc etc excuse for this message but I'm in a very bad situation Have a good day !
  5. control every part ! loosened lives residual sand of fusion in the structure after this, you can work great ! after to have audited mine c41-15 power hammer, now I work 1.58 inch square without a problem good job !
  6. John I commit nothing, my image commit to me. BUT I BUY directly on ANYANG, not buy on dealer - THIS is a difference ! The dealer control the product prior to buy
  7. many thanks for your help guys !
  8. The hammer work, but three days of my life to make up the hammer..... low quality in my onest opinion
  9. GOOD MORNING GUYS ! Is there a good formula to etch a damascus pattern ? I use this material - c-40 c-70 - c90 a solution of 70% Ferric Chloride 30% distilled water wash with water and 10% of sodium bicarbonate. polish with 600 grit or up take this formula to AES custom knife Many thanks for your help
  10. Anyang factory answer : "Good morning V. Federico, Please kindly check whether the little screw is come from the hammer rod,if it's yes,please fasten it on the hammer rod,then the top tup can reach the height to make enough hit energy. Thanks and Best regards, Susan " ok...... but ... now ..... I have already resolved the problem, I must try if it works great
  11. Good morning Mr Hofi, thank you very much for your help. I hope of being understood, I'm go, step to step - the small bolt not have a hole in it, it has only a cut for the screwdriver; on the opposite side it ends to tip - on top of working cylinder, I found a hole ("A") threaded, with the same pass of the screw - In my opinion, this screw it closes this hole ("A") on top of working cylinder; Mr. Hofi, see the image, you can see two chisel blows by hand form Anyang factory (bad handle work) See this image : Click on image to view larger image ! Top working cylinder - Anyang C41-15 - Blacksmith Photo Gallery The hammer less power because a part of the air on top the cylinder, it passes through, and loses the power. Is it a possible solution ? ------- An other ask on this image : screw stop slab - Blacksmith Photo Gallery Click on image to view larger image ! There is a image of a interior of compressing cylinder, two screw with a cut for the screwdriver ("B") they hold stops a slab, I must be use LOCTITE
  12. nothing broken .... but the situation is this :
