trattoclip
    164
Everything posted by trattoclip
  1. Hi Minotaur ! thank so much ! I had found nothing ! trattoclip2@yahoo.it it's my mail please send me an confirm (with PM) when you send the mail Fantastic ! thank you very much for your help ! :)
  2. My friend buy this hammer form a school, very very in a good condition, but need the complete manual for this hammer. I search into this forum and on the web but I found nothing ! Can you halp me for this problem ? Thank you very much ! Have a nice days !
  3. I have an anyang hammer, very good product ! I work until 40 mm x 40 mm square, without a problem ! now I use this hammer for damascus billet
  4. Hi Jura, Please stay at home beetween 48-72 hours, arrive the package. This service assure the t-rex value but make ONE DELIVERY TO YOUR HOUSE, IF YOU DOESN'T AT HOME THE PACKAGE NOT RETURN TO ME ! (because if return to me, the cost it's very hight, and I refused the return) Attention to this ! Confirm this PM. Have a nice days !
  5. Hello to all, with much displeasure I must abandon l' activity of blacksmith. cause familiar, serious reasons now I will sell all this that I have in order to gain money for other essential plans I will sell all ! This not a mechandising message... If you interested, contact me with PM I must sell all, I have need of money in order to face the adversities power hammer c41-15 (used only 15 hours) perfeclty restored, I have replaced the not perfect parts with made new of European materials I have a image to cinfirm this !) concrete and steel base hammers hofi hammer 1.3 kg, used less hours c 45 steel for tool many many chiesel a good gas forge t-rex burner etc etc excuse for this message but I'm in a very bad situation Have a good day !
  6. control every part ! loosened lives residual sand of fusion in the structure after this, you can work great ! after to have audited mine c41-15 power hammer, now I work 1.58 inch square without a problem good job !
  7. John I commit nothing, my image commit to me. BUT I BUY directly on ANYANG, not buy on dealer - THIS is a difference ! The dealer control the product prior to buy
  8. many thanks for your help guys !
  9. The hammer work, but three days of my life to make up the hammer..... low quality in my onest opinion
  10. GOOD MORNING GUYS ! Is there a good formula to etch a damascus pattern ? I use this material - c-40 c-70 - c90 a solution of 70% Ferric Chloride 30% distilled water wash with water and 10% of sodium bicarbonate. polish with 600 grit or up take this formula to AES custom knife Many thanks for your help
  11. Anyang factory answer : "Good morning V. Federico, Please kindly check whether the little screw is come from the hammer rod,if it's yes,please fasten it on the hammer rod,then the top tup can reach the height to make enough hit energy. Thanks and Best regards, Susan " ok...... but ... now ..... I have already resolved the problem, I must try if it works great
  12. Good morning Mr Hofi, thank you very much for your help. I hope of being understood, I'm go, step to step - the small bolt not have a hole in it, it has only a cut for the screwdriver; on the opposite side it ends to tip - on top of working cylinder, I found a hole ("A") threaded, with the same pass of the screw - In my opinion, this screw it closes this hole ("A") on top of working cylinder; Mr. Hofi, see the image, you can see two chisel blows by hand form Anyang factory (bad handle work) See this image : Click on image to view larger image ! Top working cylinder - Anyang C41-15 - Blacksmith Photo Gallery The hammer less power because a part of the air on top the cylinder, it passes through, and loses the power. Is it a possible solution ? ------- An other ask on this image : screw stop slab - Blacksmith Photo Gallery Click on image to view larger image ! There is a image of a interior of compressing cylinder, two screw with a cut for the screwdriver ("B") they hold stops a slab, I must be use LOCTITE
  13. nothing broken .... but the situation is this :
  14. Good morning guys ! I need help ! I don't have a good notice ... After 20 min at work, the hammer in top setting position not work great; the ram not move up to reach an ideal height (complitely into cylinder). in top setting position the ram must be in upper position, now is in lower position, the dies is in contact. I contact the Anyang factory but, them answer : I reported the problems to our after-sale department,the technicians told me that maybe the seal of valve has problem,so please kindly check the middle of valve. If you have any questions about our power hammer or need any help from us,please feel free to contact with me! Thanks and Best regards, Susan but, I would ispection the working cylinder, the piston rings is in a good condition. open the handel lever valve (upper and lower lever), I found nothing, no big pools of oil in the valves. I decice to open the cover of compressing cylinder and ....... I FOUNDA SCREW ON TOP THE CYLINDER !!!!!!!!!!!! THIS IS ABSURDITY, INCONCEIVABLE FOR MY EXPERIENCE. Anyang 33lb - Screw found into cylinder The gap beetween the cover of compressing cylinder and the compressing piston,I have measured, is little larger of the thickness of the screw; the screw not it does not have chopped herbs or damaged the piston. I decide to open all parts of hammer, to investigate it. I don't found nothing, and I do not know from where it arrives I'm abashed and they are disappointed for this, after only little hours of operation. and now I see the interior of Anyang 33lb. I upload more more more image on the gallery.
  15. same parts of hammer
  16. compressing piston bad surface (lower face)
  17. compressing piston bad surface (lower face)
  18. compressing piston bad surface (lower face)
  19. compressing piston bad surface (lower face)
  20. compressing piston bad surface (lower face)
  21. air hole into compressing cylinder
  22. interior of comopressing cylinder
