BORZ
    126
Everything posted by BORZ
  1. i have the forge ready yet,it vorks fine(just an hour experience,but i think it'll be ok'). one thing-i dont reach white heat,maybe need to increase the pressure? now it ran ~0.2 bar(dont know in psi...),it might be too low...aniway,thanks much for helping,im on the right way... here a few pics,if anybody want build one,i just can say it's not that diifficoult,as it seems first.and if help is needed,it comes also...
  2. The forge isnt ready yet,monday ill have the sheet metal,so the box may be ready next week.when ready,ill put a few pics,i hope it'll work...
  3. so i modified it a bit,i think,now it may be ok.here a few pics,and many thanks again for taking your time to help.
  4. Frosty thanks much for the help!how to center the jet?just bend,or center the whole thing? i guess i didnt weld the nut 100% perpendicular...aniway,for first i didnt expect even that it burns...so, repair,and hope the best. thanks again!
  5. burner is vorking anyway in a quite wide range of pressure- 0.2 to far over 1 bar. which pressure is used normally? few pics about the burner vorking:
  6. i started a gas forge "projekt"(first time). the t burner seemed the easiest to build,found the most advice about.it seems to vork,in a short time-i hope-i'll be ready with the forge too.i planned 3 inch durablanket insulation around,the inside is about10"
  7. mine is a bottom blast,coke fuel,the largest piece i heated so far,was a hammer~3 kgs,and it was hot quite fast. and the forge to build took a weekend,(with no hurry).i could use with charcoal too,just need to reduce air flow. i dont even think,it is more difficoult to build-just need an angle grinder,a welder,and the metall plates.-and a bit of time...
  8. BORZ
    steel springs?
    just an advice: dont quench it in cold oil, i made my chisels,and punches of coil spring, and by quenching in room temp. fluid they cracked. by heating up the oil were everything ok
