Does Ferric Chloride Freeze Well?
Does anyone know what happens to Ferric Chloride if it freezes? Does the chemical compound change and it turn ineffective or is not and just fine to use after it thaws?
I live in Alaska and sometimes we have to turn our house off when we leave and let it freeze, I don't want to be a burden to others by needing them to keep it while we are gone.
8 hours ago, BlackburnRose said:
I live in Alaska
Welcome to IFI... we won't remember that once leaving this post, hence the suggestion to edit your profile to include location.
Also this thread will help you get the best out of the forum. READ THIS FIRST
Speaking as a chemist and not someone who has actually tested this, ferric chloride should freeze and thaw without damage. That said, you need to have it in a container that will not break when the liquid expands on freezing. The active etching from ferric chloride comes from hydrochloric acid released in the solution. It just does not maintain as high a concentration of acid as you can get with pure HCl.
