stovestoker
154 -
Everything posted by stovestoker
Out of the box thinking with scrap yard parts is exactly what I am looking for. Hope this thread keeps going. The tines are 3 feet in length on the bottom skids. About 18 inches from the L to where they are attached to the frame. Not super big but the uper supports are 1.5 inches thick. I will be forging knives, meat turners and bottle openers. Working my way up to gate hinges and fineals (sp?)
If you were going to build an anvil out of material found in a scrap yard, what would you use? For example, I found some fork lift tines today. Would they make a good anvil? Should I be looking for something to make a post anvil? Do I stick with rr track? What pieces parts should you look for and how would you put them together?
Whats wrong with this Hay budden?
stovestoker replied to stovestoker's topic in Anvils, Swage Blocks, and Mandrels
Looks like the cut is right in the middle of the sweet spot. I need an Anvil but I don't think this one is worth the 300. I could be wrong. -
Found the on CS for 300. looks like someone to a grinder to the face?
Quick question, decent for edged tools or knives?
stovestoker replied to stovestoker's topic in Knife Making
Yes cultivator. But I figured plow blade was a term that was common enough for everyone to understand. these blades actually run under the soil. They break up the soil so the soil takes water better. The blades also take out weeds like careless weeds from the root under the surface. A friend of mine from a nearby farm town said that his father would take them to the blacksmith in town for sharpening. So some of the old ones have probably had a blacksmith hands on them. Kinda cool to think about. Full circle. Going to pick up a couple now, -
These are actually plow blades. they come in different sizes. depending on how you want your furrows laid out. -
I see a lot of these at the scrap yard and they look like they would be good for knives or choppers. what kind of steel are they? will they hold an edge?
That a neat little forge.
Yup, I live near an air force base. It came off a b 29. I got it from a guy of was an aircraft mechanic during wwII. I was going to use it for a hot rod gas tank. But it was to cool as it.was. when I get the shop built I think I will just hang it up somewhere.
I just picked up this little forge. It is a my first "real" forge. The duck foot looks home made, or not original but I think it will work. the inside says to clay. The guy I got it from didn't know about claying so he built a liner out of 3/4 inch steel and a grate from thick stainless. He never built a fire in it so I'm not sure if the whole collection is going to work. I was wondering what the screws in the side of the pan are for. They go all the way around the pan. Not sure if anyone recognizes who may have manufactured it.
What do you use for tubing to connect your blower to forge?
stovestoker replied to stovestoker's topic in Bellows, Blowers
That does sound cool. -
Well how did I do with this stuff?
stovestoker replied to stovestoker's topic in Blacksmithing, General Discussion
That last sentence was a joke. I am too much of a romantic to use something so beautiful in such a crass manner. -
I tried the resistance nut, it bound up when I took it out a couple threads. I think the bearings/bushings are worn. It may just take a good cleaning. still it blows good and the exercise is not bad for me. Yes too bad the vise is not in great shape, but I didn't want to leave it behind. Maybe I will come across a replacement screw. Or Ill clamp a flat piece of steel on it and use it for a beer table in the shop :P -
I don't see a mounting bracket. the pin that holds the lower part of the vice together is slotted with a wedge instead of a bolt. the vice is forge welded together. you can see the welds. -
I hope its as simple as that. though I have been looking at stuff online for repair info. I soaked all the outside nuts, bolts and screws with pb blaster. going to take another look in the morning -
No, lol even though I don't leave home without one. I think the guy had the stuff listed for so long, plus I was the only one willing to drive to BFE to pick the stuff up. He also mentioned something about a wife, too much junk, no room in the drive way. I probably should have been shaking her hand too. -
I found a guy on craigslist of was willing to work with me a on some things. It cost me 240 and 30 for gas. How did I do? Champion blower on stand, spins free blows good, but turning the handle takes work. Forge pan on stand. Not sure what kind of forge it is. I may post more pics and questions in the solid fuel forge section. The duck foot looks home made. 2 post vises, both are missing springs. I believe the one on the left is 18th century. I will follow up in the vise thread. 100 pounds of coal old quench bucket and soup can water sprinkle can. He threw in a dozen RR spikes too. Didn't need them but it was nice of the guy. All came off an old farm here in Texas
Awesome Lunch Brake, Found This Old Girl
Thanks Direwolf will do! Thanks for the info too! -
The piston is from a single piston engine. He said that it used a glow plug, not unlike a giant model airplane engine. Believe it or not he said the way you started it was by walking a giant wheel , like a squirrel cage. A guy got on the wheel and walked until the engine fired. He said it was dangerous but effective. -
I took my nicest piece of track to a local machine shop. I wanted to see if he could surface it flat for me. I have tried another piece with a grinder and it came out ok. He did it for 50 bucks which I thought was reasonable. It came out beautiful. If I can get the weather to cooperate I can fire up my forge and try it out.
don't want to put the cart before the horse. just have to see if I get lucky enough to get it
