locky.au Posted January 28, 2009 Posted January 28, 2009 Hi, I am currently trying to setup a home smithy and building a coal forge etc. Has anyone fabricated a butterfly or slide type air gate before? Any plans or pictures to assist with building one would be greatly appreciated. Thanks in advance. Locky Quote
tech413 Posted January 28, 2009 Posted January 28, 2009 I made a sliding gate valve by cutting a slot in some 2" scet. 40 pipe and making a 1/8" plate to fit. I'll get some pics later today. hope it helps. Quote
locky.au Posted January 29, 2009 Author Posted January 29, 2009 I would appreciate any advice and pictures.... Cheers... Quote
philip in china Posted February 3, 2009 Posted February 3, 2009 Have a look at Vaughans (Hope Works) - For all your Blacksmith, Foundry, Farrier needs. Now available Ironworkers and Bending machines It is Vaughans (spelt like that). Their online catalogue has an air gate as well as a whole load of other things and has been the inspiration for many of my projects in tooling. Quote
tech413 Posted February 3, 2009 Posted February 3, 2009 I finally got the pictures today. Here they are, pretty self explanitory. Quote
locky.au Posted February 6, 2009 Author Posted February 6, 2009 G'day Guys, thank you very much for your support and information. Phillip thanks I will reverse engineer some of that and Tech413 really appreciate the effort in taking the pictures and posting. Pictures are so helpful in building something new. Thanks again. FYI, you can view the Coal Forge I am building which the air gate is for in my Galllery Album "Fabricated Coal Forge". There is a series of 27 pictures of how I am building it. Quote
veganforge Posted October 24, 2012 Posted October 24, 2012 I have just looked at Tech413's pics and had a 'duh' moment. Great solution for an airgate. I plan to make one very much like it this weekend. A few weeks ago I purchased a Roger Lorance fire pot. After installing it with a little blower, it worked so well that I now need to put the airgate on. Thanks again for the idea and great pics. I am also adding to my portable forge some ideas I got while working as a student at Touchstone, a teaching lab for blacksmith's south of Pittsburgh Pa. It's great that so many are willing to share information and ideas. Dave A Quote
Ten Hammers Posted October 24, 2012 Posted October 24, 2012 There will have been MANY threads on the site with information regarding airgates. I'll re-post mine here. That also is a Roger Lorrance pot (with my shop built ash dump/tuyere ). I might add that these pics show the old (original for me ) power blower. will trya and find the pics with the new blower. Last picture shows the new blower on the same airgate. Of course much better performance but the old one was used a LONG time before it died. Some will get hung up in someone elses specifications of CFM's needed, volume needed, yada yada yada. Fact is, the old blower worked fine until I traded for the new one ( which was several years old). The airgate was built from a scrapped 3" hydraulic cylinder tube. The stand is just telescoping square tube that gives height adjustment. The speed control in the last picture ( maybe Glenn can crop that picture a bit) is for the blower on the gasser. Solid fuel runs wide open and the gate regulates the air. BTW Tech 413, you have built an outstanding airgate yourself. Quote
