Houaha Posted November 6, 2008 Share Posted November 6, 2008 i have been thinking about using aluminum for a bit and i was wondering how i could build a melting furnace for melting scrap aluminum. i was also wondering could u melt aluminum cans(soda cans, etc.) to make aluminum bars? We get a lot of soda cans every week, so i think we would have enough to make some small sized bars. also how much would it be to make a melting furnace for aluminum? i would like to use propane or possibly electric. Link to comment Share on other sites More sharing options...
Woody Posted November 6, 2008 Share Posted November 6, 2008 we used to melt aluminum cans in a tin can in a campfire. It should be no problem in a propane fired forge. I am not sure what quality of bar you would get but its worth a try. Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 so does anyone have a plan for a forge? i cant think of anything Link to comment Share on other sites More sharing options...
highlander Posted November 7, 2008 Share Posted November 7, 2008 contact moya034 on this site, he does aluminum casting. metalliferous does as well. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 7, 2008 Share Posted November 7, 2008 Gingery wrote a whole series where he started by making a melting furnace for Al, (either propane or charcoal versions) and then by casting and hand work built a metal lathe, shaper, etc.David J Gingery Publishing Title List also check out all the old tech books at Lindsay's Technical Books great catalog! Link to comment Share on other sites More sharing options...
Oldiron Posted November 7, 2008 Share Posted November 7, 2008 Take a look through this site: melting metal in a home foundry, backyard metalcasting, metal casting. Lots of good information. Link to comment Share on other sites More sharing options...
czbohunk Posted November 7, 2008 Share Posted November 7, 2008 if you can find some kind of ceramic pot place 2 fire brick under the pot to set it on and around it 3 brick's higher then the pot like a kiln then a large propane torch ,open up a hole on the side by moveing 2 or 3 bricks to set the torch in close to the bottom and then fire it up. Put all your aluminum in the pot before you heat it up ,Aluminum pours at 1200 deg. if you have a Foundry close to you ask if they have an old pot you could have and if they use hard sand made with "pep-set" fourms ask if you can have a large piece make a groove in it then pour your aluminum in it SLOW VERY SLOW. Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 another question can u use cupcake trays as ingot molds? Link to comment Share on other sites More sharing options...
highlander Posted November 7, 2008 Share Posted November 7, 2008 dont know about cupcake trays, but i know one thing... if your ingot mold is a little bit rusty, then your ingots wont stick to the mold as much as a clean surface. cupcake trays sound like a bad idea to me. they are just stamped together and could come apart with rapid heat change, spilling molten metal all over. Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 so have a rusty mold? so it wont stick? Link to comment Share on other sites More sharing options...
highlander Posted November 7, 2008 Share Posted November 7, 2008 Casting ingots easy to make ingot mold is pictured, just a bunch of angle iron welded in a V pattern. when working with molten metal, be sure you have ALL the safety gear you need. Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 (edited) thx for that site now i want some angle to make a couple molds but i don't have any now for the safety equipment that includes gloves, work boots, safety glasses(i would wear a face mask not safety glasses because i wear glasses and its uncomfortable for me the wear them), and...what else? lol Edited November 7, 2008 by buddy215216 Link to comment Share on other sites More sharing options...
hill.josh Posted November 7, 2008 Share Posted November 7, 2008 Get some GOOD protection for your arms. It was raining hard and just wanted to finish the pour (I work outside) and some hit on the outside of my elbows.. both of them. They actually got infected which wasn't fun. Other than that you look like your good to go. Might wanna get some chaps too though. Good luck with it. And a side note: you don't even need to heat it up when forging it always cracks when I heat it. Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 ok thx ill look for some arm and leg protection Link to comment Share on other sites More sharing options...
Sabre Posted November 7, 2008 Share Posted November 7, 2008 i melted cans in a charcoal forge before...i melted them in a bean can..the bean can melted and the alum got stuck in the ash dump:( Link to comment Share on other sites More sharing options...
Houaha Posted November 7, 2008 Author Share Posted November 7, 2008 lmfao oh well careless mistake could happen to anyone lol(would of happened to me if u hadent said that lol) Link to comment Share on other sites More sharing options...
48willys Posted November 7, 2008 Share Posted November 7, 2008 I'v melted it in my forge before,wasn't hard at all.If you use cans crush them or they will burn,the best way is to get a little pool started with some thicker stuff like a old lawn chair and then add the cans. As for a crucible (pot for melting) you can weld a plate on the bottom of a pipe ,but it would need to be a water tite weld.And you do need to "season" it,bring the whole thing to red heat and set it out to cool slowly that will allow scale to form and keep the AL from eating it. As for cupcake pan for ingots,they use them alot over at the metal casting site so I guess they work ok.But I haven't tried it yet. MOST IMPORTANT, safety .I would go to the metal casting site to read about safety melting metal in a home foundry, backyard metalcasting, metal casting Molten aluminum & water is a bad idea,don't do it in the rain or on wet pavment. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 7, 2008 Share Posted November 7, 2008 Even a drop of sweat falling from your forehead into a mold can result in an eruption of molten Al and you end up spending thousands of dollars for hospital bills but being able to save money on Halloween costumes as the scars will let you go as a horror show star... (And Al is probably the easiest of the +1000 degF melting metals to work with!) Link to comment Share on other sites More sharing options...
Justin Caradoc Posted November 7, 2008 Share Posted November 7, 2008 cupcake pans work great for ingots. Link to comment Share on other sites More sharing options...
Mende Posted November 7, 2008 Share Posted November 7, 2008 Just put a steel or cast iron melting pot in the hottest part in your forge . .I tried it with copper and it worked. . .try to cover up everything so as t minimize heat loss. . .also try to have a non oxidizing flame. . it will burn thru ure crucible if you use a steel or iron one . . Link to comment Share on other sites More sharing options...
millwright Posted November 7, 2008 Share Posted November 7, 2008 Even a drop of sweat falling from your forehead into a mold can result in an eruption of molten Al Aluminum explodes with 300 times the power of a similar molten iron explosion I would suggest preheating to drive all the moisture out of your scrap especially if you are using cans. Many aluminum factories around the world have been leveled this way. I'v melted it in my forge before, wasn’t hard at all. If you use cans crush them or they will burn, the best way is to get a little pool started with some thicker stuff like a old lawn chair and then add the cans. All due respect but this procedure is the exact recipe to cause a molten metal explosion. Cans and the little swig that you cant quite get are so dangerous that the aluminum plant that I work at will fire you on the spot for having an aluminum can on the property. Pre heated and dried out cans cause no real danger but adding a can that contained a teaspoon of liquid to already molten metal is would be like lighting a stick of dynamite. Please be careful when dealing with molten aluminum. John W. Morris Area Maintenance Planner Alcan Global ATI Ravenswood, WV Producers of aluminum coil and plate products for aerospace, transportation, and industry Link to comment Share on other sites More sharing options...
orgtwister Posted November 8, 2008 Share Posted November 8, 2008 i have cast many aluminum items for restoring motorcycles with a friend of mine i your going cast aluminum you need to use cast aluminum if you use cans it wont cast well you need to use cast aluminum you can mix in some cans but pure aluminum doesn't cast if it was me scrap the cans and get some scrap cast aluminum when you reliese what cast is out there there is plenty transmision cases intakemanifolds if you need other info on this i have done alot message me Link to comment Share on other sites More sharing options...
petersenj20 Posted November 10, 2008 Share Posted November 10, 2008 (edited) A lot of people use coke cans and like for their casting. It works just fine. As long as you have the patience for the time it takes to crush and melt enough to have a substantial mass. You will have a lot of dross to scrape off, but like I said patience. I use almost strictly cans with the occasional oxygen cylinder(that'll raise hollers from the crowd I know, but I am safe). My furnace is large enough I can use it as a scrap melter placing metal right in the fire and tap from the bottom. Also, I use wood exclusively in this furnace and is totally free. Edited November 10, 2008 by petersenj20 Add sentence Link to comment Share on other sites More sharing options...
philip in china Posted November 10, 2008 Share Posted November 10, 2008 Moulds are made for lead by companies like RCBS and Lyman who supply reloading equipment. They work fine on lead so should be OK unless anybody wants to correct me on this. Link to comment Share on other sites More sharing options...
highlander Posted November 10, 2008 Share Posted November 10, 2008 Moulds are made for lead by companies like RCBS and Lyman who supply reloading equipment. They work fine on lead so should be OK unless anybody wants to correct me on this. lead melts at 621*F aluminum melts at 1220*F the cast aluminum lead ingot molds arent designed to take the kind of heat that molten aluminum gives off. Link to comment Share on other sites More sharing options...
Please sign in to comment
