Help identifying Insulating Fire Bricks
I recently got a great deal on a bundle of these IFBs (38 of them for $40).
They are not like the lightweight white IFBs I am used to. They are much more like regular hard (non-insulating) fire bricks, but they are clearly marked IFB.
They measure 2.5”x4.5”x9 and I did not weigh them, but they weigh about as much as a brick should - not lightweight like the white ones.
Can someone help me identify what type of brick (high alumina?) and maybe a max temp associated with the type?
TIA
Bonus question: there are two in the bunch that are slightly smaller and are marked EJB. Identification on those?
Do a web search for, "IFB Refractories." They do make "insulating fire brick" of all types and it is in fact the company name. They've been around since 1919.
The above is probably why most refractory makers call their insulating brick, "Light Insulating Fire Brick" or similar or other name that doesn't infringe on patent and copyright laws.
Please don't use the  @ tag with names it messes up the forum OS. It isn't a chat type system.
You'd have to talk to the company to see if there is a way to ID what you have. I'd just test to see how much heat they can take, an Oxy Acet torch will get way hotter than you or I will likely ever need. You can call a ceramic or kiln supply and see what temperature cones are available and test with them.
  I'll try for the bonus question concerning the EJB bricks.
  I found this:
https://www.daves-brick-collection.com/2023/05/brick0311-ejb-union-mining-company.html?m=0
  Which led me to this:
http://www.mountsavagehistoricalsociety.org/brick yard/history of union mining company.htm
  I couldn't find specifications. Some history and identification if nothing else.
  Like rust, technology never sleeps:
https://news.mit.edu/2024/electrified-thermal-decarbonizes-heavy-industry-with-thermal-batteries-1126
