Rhino head
Rhino head, not many pictures of the process. And I will be making some sort of a backplate. Second horn (more of a hint of a horn) is a bit squished, no way around it.
I like it Davor, well done. Making the second horn is only a matter of leaving the steel when you set it down for the first horn and jaw. Basically flip the bar over after you do the set down for the nasal horn and leaving a LITTLE for the second horn off a rounded edge of the anvil on the 1st horn side drive it down a LITTLE. Then leave the resulting step a bit over the far rounded edge (IF you have to walk to the far side of the anvil or spin it around!) Set it down. This leaves you a high spot in the bar behind the nasal horn and in front of the "head."
It's a good thing to practice with modeling clay, (plasticine) before taking it to the fire and anvil.
Thanks guys I've been thinking about it for a week before I started hammering. And now Frosty got me thinking about that second horn and when I find the time I have to give it a try.
There are other ways to isolate material for the second horn. Doing the set downs on a horn or a sharpish bottom fuller would be another probably better method. As a win win you might have to make or buy a tool or two. ;) The second horns are usually much smaller than the nasal horn though there is a wide range in shapes and size. It was fun just looking at images and I learned there is NO one way to make a "realistic" representation of a rhino.
Rhinos have a muzzle, so extending it a little before cutting the mouth would make a little better representation.
I especially like brainstorming things here. :)
