JHCC Posted February 15, 2024 Share Posted February 15, 2024 I'm not suggesting anyone actually build this version of a tire hammer, but you've got to admire the creative simplicity of it. Screen grab from https://www.facebook.com/reel/1888340998286554 Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 16, 2024 Share Posted February 16, 2024 We don't need no STEENKEEN SPRINGS! Pretty slick, I love ingenuity in action. We used to put a tire between in the tow chain and tow vehicle to cushion the tow. Tires are excellent shock absorbers. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 16, 2024 Author Share Posted February 16, 2024 I’ve got a forklift tire on the back of my treadle hammer to absorb the force of the arm stopping at the top of its upstroke. Works really well. In thinking about the video, I realized that there’s really not much difference in principle between the tire and the rubber straps on a Bradley. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 16, 2024 Share Posted February 16, 2024 Except for the price . . . BINGO! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 16, 2024 Share Posted February 16, 2024 For the first iteration of my DIY power hammer I used tow straps instead of a linkage. I wanted to minimize the number of metal on metal wear surfaces. It worked ok, but with the design I used it required fairly frequent adjusting/tightening to keep everything lined up properly. This makes me wonder if I could use a tire instead of the entire linkage/spring assembly. Unfortunately the tension on the linkage arms does affect how well the hammer runs, and I'm not sure there's a reasonably good way to change the tension on a used tire. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 16, 2024 Share Posted February 16, 2024 Change tire size and band around the tread with poly rope or webbing for fine control. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 16, 2024 Author Share Posted February 16, 2024 Or have an adjustable mounting bracket? Quote Link to comment Share on other sites More sharing options...
Scott NC Posted February 16, 2024 Share Posted February 16, 2024 I've never built a hammer but love anything that employs a crank. That is pretty cool. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 16, 2024 Author Share Posted February 16, 2024 I guess that means you love everyone who’s ever given me a job! Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 17, 2024 Share Posted February 17, 2024 Adjusting throw and blow weight is a matter of adjusting the spring tension, not mounting brackets. Unless the hammer in question was built very differently than any I've ever seen and I have The Powerhammer book and a number of saved files of old power hammer patent drawings from when I thought I'd have to build my own. I'll try this analogy, maybe it'll draw a useful picture. The adjustment to the arm mount on the crank pin. Is like getting the timing chain and timing sprokets set properly. You time the motor with a light and mark on the flywheel just like you adjust the hammer by adjusting spring tension on the link arms. I can't see enough of the tire spring hammer but I don't see anything to suggest adjustability, crank or hammer arm. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted February 17, 2024 Share Posted February 17, 2024 29 minutes ago, JHCC said: guess that means you love everyone who’s ever given me a job! Only because it's carried me this far as well! Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 17, 2024 Share Posted February 17, 2024 I'm a fan of cranks too, besides my friends here. I was drinking coffee and sketching on my pad of graph paper in the old Country Kitchen restaurant when a friend, Cruz, walks by glances at the sketches of a drive mechanism for a power hammer I was working on and said, "Scotch yoke" and walks back to the conference table the coffee club hung out at. I sat there blinking and thinking for a minute then got up and headed back to ask what the heck he'd said and what it meant. Took good old Cruz maybe 90 seconds to describe what and how a scotch yoke works. I was danged close to reinventing a crank mechanism but was compensating for motions a scotch yoke damps naturally. Then before I got more than materials collecting started I got a deal on a 50lb. Little Giant and never built my design. Were I up to it I MIGHT have tried converting the linkages on my LG to a scotch yoke drive and reveled in a LG that didn't want to go walk about in use. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted February 17, 2024 Share Posted February 17, 2024 Some designs of metal shapers run on Scotch yokes. I've thought about using them to make sculptures wave at people. Until I found 1800 mechanical movements book and forgot about that idea and started in on a new one.... or two. I'd reccomend it. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 17, 2024 Author Share Posted February 17, 2024 I thought a Scotch yoke was what you get when you marry a Caledonian. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 17, 2024 Share Posted February 17, 2024 Not if you don't capitalize it. I'll have to keep my eyes open for the book Scott, it sounds like a good one. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 17, 2024 Author Share Posted February 17, 2024 Or is it what’s at the middle of a scotch egg? Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 18, 2024 Share Posted February 18, 2024 This really has you deviled doesn't it John? Keep trying you'll crack it eventually. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted February 18, 2024 Share Posted February 18, 2024 A key ingrediant in Scotch Haggis Balls. On 2/17/2024 at 8:38 AM, JHCC said: what’s at the middle of a scotch egg Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 19, 2024 Share Posted February 19, 2024 I love Haggis, especially with a dram of single malt scotch to wash it down. For a long time it was banned here in the U. S. until recently (2021) when the ban was lifted. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 20, 2024 Share Posted February 20, 2024 What tripe! When I think about haggis I often feel happy I don't know anybody who makes it. And I'm part Scot. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 20, 2024 Author Share Posted February 20, 2024 I was very lucky that the first time I had haggis, it had been made by a Michelin-starred chef. It was exceptionally good. Quote Link to comment Share on other sites More sharing options...
