Xforce Posted September 14, 2008 Share Posted September 14, 2008 (edited) im new here but i just wanted to show you my idea of what im going to build. this forge is really easy to build (i hope so). i dont have all the things yet but this is my building plan. i think that it would be a great forge for beginners like me. heres a picture a made with paint (Remember it is only a sketch) i hope you like it if you have any ideas for this build than i would love to hear it! thanks! ***EDIT*** this was just a quick sketch! im working on it. one of the issius in this sketch are that if some coal drops in the bucket than you cant get it out of there. so maybe i need to make some kind of door in it. or just a small hole in the bucket. ooh and if you have a good name for it than go ahead and post it! Edited September 14, 2008 by Xforce Quote Link to comment Share on other sites More sharing options...
Golden_eagle Posted September 14, 2008 Share Posted September 14, 2008 I have a gas forge, but i have experimented with wood(charcoal) forges. during this build you can make a Ground forge by digging two holes next to each other and putting a tunnel between them and hairdryer in one hole and fire in the other Quote Link to comment Share on other sites More sharing options...
Xforce Posted September 14, 2008 Author Share Posted September 14, 2008 good idea! thanks! Quote Link to comment Share on other sites More sharing options...
fat pete Posted September 14, 2008 Share Posted September 14, 2008 hey x your close to correct ..I dont think the wok would woork for long tho....take a look at the 55 forge its in the b-prints and there is a thread on it Quote Link to comment Share on other sites More sharing options...
hill.josh Posted September 15, 2008 Share Posted September 15, 2008 the wok is a great idea.. but the fire will eventually burn through it so you might wanna cover it with some mud, and make a smaller bowl out of it. somethin like 6-8in. dia. if you find you need a bigger firepot just get rid of some of the mud and might want a valve of some sorts to control air flow. i'll try and get some pictures up of one ive got but other than that you look like your good to go. you could shorten the pipe alot and use pvc if you haven't bought it yet too. Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 15, 2008 Share Posted September 15, 2008 i seen a guy on the web make crucible furnace simalar to that he used to big coffe cans blower going into the bottom can the top one had holes drilled in the bottom and he had the crucibal and charcoal in it and he metled aluminum in it but it was good for a one time use in yours i would think of using a cast iron roaster might last longer but if you can heat it hot enough to forge it thats all that maters i have made forges out of brake dumes ,propane tanks my self i like to make a lot of my stuff to say thats mine Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 15, 2008 Share Posted September 15, 2008 Looks a pretty basic design for a solid fuel forge but a few large hole in the bottom of the wok would be better and an ash dump in the bottom of the dish. Add some sandy mud and you are away. Have a look in the Blueprints for ideas. Quote Link to comment Share on other sites More sharing options...
jayco Posted September 15, 2008 Share Posted September 15, 2008 X-Force, you pose an interesting idea........one worthy of experimentation. I took a look at your sketch and thought "HMMM....There's something new here!" I may be looking at it all wrong, but I'm thinking the forge itself could be a piece of flat plate, a wheel (with the unneeded lug bolt holes filled with mud, with holes or slots for air to enter the center of the fire. The 'bucket on the bottom' is what is different. If the horizontal air pipe connects 4 or 5 in. up the side of the bucket, there would be ample room for the ash to collect from several fires. When the bucket filled enough to clog the airway, then just lift the cold forge off the bucket, empty the ashes, and your good to go.......I think! There would need to be some sort of seal around the top of the bucket to force as much air as possible into the forge( I'm thinking mud) It seems to make sense that whatever amount of air entered the forge, it would escape up into the forge.The only thing I'm not at all sure about is would the blast into the forge be focused like a traditional forge or would it just leak out in all directions making use difficult? That's a good question! This is an interesting idea.....I'll have to try this! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 15, 2008 Share Posted September 15, 2008 I'd suggest *TESTING* it before suggesting it to others. My earliest forges went through several variations before I got it nailed down to do what I wanted. BTW have you see the Tim Lively wash tub forge? Engineered more for bladesmithing and using charcoal for fuel; but easy to build and use. Quote Link to comment Share on other sites More sharing options...
inazuma_x Posted September 15, 2008 Share Posted September 15, 2008 another good design i've seen around is using drum brake housings as the firepot. Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted September 16, 2008 Share Posted September 16, 2008 If a wok, a metal bucket, a section of pipe and a hair dryer is all you got, go for it but I don't think the wok will last long without being lined. Why not try and find a used break drum and make a forge that way. It will last a lot longer.:confused: Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 16, 2008 Share Posted September 16, 2008 If you have to use a wok, why not a side blown design? Quote Link to comment Share on other sites More sharing options...
inazuma_x Posted September 16, 2008 Share Posted September 16, 2008 I'd suggest *TESTING* it before suggesting it to others. My earliest forges went through several variations before I got it nailed down to do what I wanted. BTW have you see the Tim Lively wash tub forge? Engineered more for bladesmithing and using charcoal for fuel; but easy to build and use. i was on the cusp of making a washtub forge before i moved into my new house...i've heard they work a treat Charcoal Forge its quite an attractive setup too IMO Quote Link to comment Share on other sites More sharing options...
jimbob Posted September 16, 2008 Share Posted September 16, 2008 If you've never built a forge its a good plan to start with , from there you can find out what works good...it leaves a lot of room to play around with Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted September 16, 2008 Share Posted September 16, 2008 That wash tub forge looks a lot better then the wok forge. I say go for it.:D Quote Link to comment Share on other sites More sharing options...
Max Mulholland - Tetnum Posted September 16, 2008 Share Posted September 16, 2008 (edited) it would seam that it would burn through but i used a tin can with nail holes, a shop vac and some logs for my first forgeYouTube - forge tour i have sceine upgraded to coal but that can lasted and about 4 inches were left bare iron as a grate and it lasted for some odd reason so the wok is definitily a a higher gauge twere just make shure its not Al and you will be fine Edited September 16, 2008 by tetnum Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 16, 2008 Share Posted September 16, 2008 So why not a Wok-tub forge? Use adobe to line the wok and shape the firepot... Quote Link to comment Share on other sites More sharing options...
Xforce Posted September 19, 2008 Author Share Posted September 19, 2008 thx guys for all your ideas and replys! it finished it a few hours ago. Quote Link to comment Share on other sites More sharing options...
