hammerhandsyd Posted September 10, 2008 Share Posted September 10, 2008 im biulding a shop that has a forge, exept that its realy 4 diffrent forges. im debating wether or not to connect all forges witth a chimmeny or just have four diffrent chimmenys blue prints would be nice:D Quote Link to comment Share on other sites More sharing options...
philip in china Posted September 10, 2008 Share Posted September 10, 2008 Many old forges had several forges going into 1 chimney so it does work OK. Individual chimney for each forge would be simpler but the combined one would be more elegant. What are you going to use to build it? Brick, pipe etc?? Quote Link to comment Share on other sites More sharing options...
Blacksmith Jim Posted September 11, 2008 Share Posted September 11, 2008 Somewhere on this site Hofi posted some pictures of his forges and chimneys at one of the schools he runs. I remember it standing out as a nice simple design. He had a chimney for each station, but the stations were near the wall, and the chimney went out the wall before it went up. Maybe you can find the pics in the gallery.. Quote Link to comment Share on other sites More sharing options...
Atticka Posted September 11, 2008 Share Posted September 11, 2008 Your thinking of "BP1048 Side Draft Chimney" that shows off the individual student workstations, each with their own chimney. Other thing you want to consider is discretion, four different chimneys may draw unwanted attention depending on the neighborhood or nature of your shop (residential or commercial, etc...) Quote Link to comment Share on other sites More sharing options...
Doug C Posted September 11, 2008 Share Posted September 11, 2008 Here is the link to the pictures of Hofi's chimneyshttp://www.iforgeiron.com/forum/f7/forge-chimney-5084/index2.html#post46699 Quote Link to comment Share on other sites More sharing options...
firegnome Posted September 12, 2008 Share Posted September 12, 2008 I saw a working shop that had an old restaurant hood and fan system and they had 4 coal and 3 gas forges all being serviced. Granted it was a tad cold if you opened the door in the winter with it trying to suck all through the hood. But they mounted a pair of long gas heaters hanging from the ceiling and that improved it. Firegnome Quote Link to comment Share on other sites More sharing options...
ironrosefarms Posted September 15, 2008 Share Posted September 15, 2008 I think a question to be asked is will more than one of the four forges be lit at the same time? If not you could have a gate or door to close off the unused sections. But if it is possible that 2, 3 or 4 forges will be lit at the same time you will have to consider how much chimney will be required to draw with multiple openings to go into one chimney. I have a friend that has 3 wood stoves in his home, all 3 go to one brick chimney. however inside that chimney is three separate pipes so each pipe has it's own draft. James Quote Link to comment Share on other sites More sharing options...
hammerhandsyd Posted September 27, 2008 Author Share Posted September 27, 2008 thanks every one ill check out all the items u recomended. i liked the idea of one chiminey with seprate pipe chimenys inside it. i am located in the our skirts of town were only the noise from a nice beautiful anvil is a problem, the chimenys lead to the back of my property so the smoke will disapate before it clears the tree line even if i have all 4 forges running. i will only have all forges runing maybe once a year. Quote Link to comment Share on other sites More sharing options...
hammerhandsyd Posted September 27, 2008 Author Share Posted September 27, 2008 note: one of the forges is going to be a side draft and one of them will have no hood Quote Link to comment Share on other sites More sharing options...
