Gromgor Posted June 12, 2013 Share Posted June 12, 2013 A friend of mine works for a company that used to have railroad track installed for some purpose. They have the track just lying around and they've said he can get all of it that he wants. So I'm curious what are some ways to cut RR track are. Quote Link to comment Share on other sites More sharing options...
Dale M. Posted June 12, 2013 Share Posted June 12, 2013 For the average "joe", probably Oxygen/Acetylene rig with big cutting tip..... If you have something similar to a 12 inch capacity cutoff saw (which most of us don't) that would work... Anything smaller is a exercise in futility.... Dale Quote Link to comment Share on other sites More sharing options...
batesblacksmithshop Posted June 12, 2013 Share Posted June 12, 2013 6" grinder,cutoff wheel dont take long at all. Quote Link to comment Share on other sites More sharing options...
Dan C Posted June 12, 2013 Share Posted June 12, 2013 I've used a 14" chopsaw, cut from the bottom, when there's very little left pick it up and drop it on another piece of rail. You should get a clean break. Quote Link to comment Share on other sites More sharing options...
5starhobo (blake) Posted June 12, 2013 Share Posted June 12, 2013 You could use a oxy/ac torch, but it won't turn out nearly as clean as what dcraven mentioned. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted June 12, 2013 Share Posted June 12, 2013 Dcraven, Does that technique work well when you're just cutting off a small section (torch cut end) to make a clean cut end? with the cut section being less than 1" long? Quote Link to comment Share on other sites More sharing options...
Dan C Posted June 12, 2013 Share Posted June 12, 2013 I don't have an OA cutting torch, and have only used the chopsaw as mentioned above. I was cutting larger sections to use as an anvil for either myself, or for friends. I did have intentions on cutting smaller pieces to use as hardy tools until I found that jack hammer bits are readily available at tool rental places for next to nothing and easier to work with considering the tools that I have. Besides the piece of track mounted vertically, I only have one 2 foot section of track remaining which is useful for other things, ie. straightening large pieces of steel by heating them, setting it on the ground and then pressing the track on top of it, so I decided against cutting it up. Quote Link to comment Share on other sites More sharing options...
aparofan Posted June 12, 2013 Share Posted June 12, 2013 I've made two anvils from track before I got my hay-budden. First one I did with an angle grinder and it took a little while but cut was clean. Second one was with o/a torch and was kind of tricky when you got to the top of the track but didn't take long at all. Problem was the torch cut track is a nightmare to clean the edges up, might as well used a grinder to begin with. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 12, 2013 Share Posted June 12, 2013 RR rail isn't some mythical substance, you can cut a rail in about 20 minutes with a hack saw and 14tpi blade Cut from the flange towards the face, tip it slightly so you NEVER put the teeth on the rail surface. Only the contact/wear face of rail is induction hardened, the rest is normalized. I use my HV band saw to cut rail, no sweat, no muss no fuss. Cut from the flange with just enough tip so the blade ALWAYS comes on the wear surface from underneath. If you're in the field you can cut rail really easily with a little ingenuity, a good cold chisel, hammer and a bar. Score the flange and web with the chisel, lift the rail as high as reasonable, 2" at least. Use the bar to pry it up and block it to hold it. Put a rock or another piece of rail under either the end or where you scored it and push it off the blocks. the shock of impact will snap it at the score marks. this is how the rail hands do it, or used to. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted June 12, 2013 Share Posted June 12, 2013 The only reason I ask is because I've got a few sections of rr track. all are under 4' long, closer to 3' or less. All were torch cut. I'd like to clean up the ends but not cut off/waste more than I have too. The two longer sections will be cut to matching length and used as the base for the shorter section which will be dressed to look like a traditional english anvil as best I can with a grinder and cutting torch. I'd like to have a clean cut end oposite the horn which would mean using the 14" chop saw to cut it clean but I want to know if I need to cut all the way through with the saw, or if I can get close and than manage a clean break at the track surface. I plan on leaving the top side of one of the supporting sections hanging out on the non-horn side of the base to give me another area to use as an anvil/hardy tool giving me the best of both worlds as far as track anvils go (vertical and horizontal possitions). In order to do this I need the ends of the supporting tracks to be straight meaning a torch cut is out of the question. The vertical track will be sunk into some hardwood to act as the base. of the full height anvil. no, I'm 6'5" can anyone give me a recommendation on the best approximate final working height of an anvil for someone my size? Quote Link to comment Share on other sites More sharing options...
macbruce Posted June 12, 2013 Share Posted June 12, 2013 I cut it with my bandsaw, a Roll-In, with no problem. I set the speed at it's lowest fpm with light to medium pressure and use a 14/10 bi-metal blade. It takes around 10-15 minutes. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted June 12, 2013 Share Posted June 12, 2013 alas, that is one of the few tools I don't have, a metal cutting band saw. Thow it is on the list. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 12, 2013 Share Posted June 12, 2013 The general method for gauging proper anvil height is to stand relaxed with your hand at your side. The anvil's face should contact your hand somewhere between your knuckles and wrist. Old school says knuckle height but that isn't as comfortable for a man striking one handed. during his clinic here a few weeks ago Gordon Williams showed us a really handy gauging technique. He holds a pair of tongs in his holding hand and sets the anvil height at a level where they lay flat on the face. OR he sets the anvil where tongs held between his legs are flat on the surface. Holding the tongs between your legs is how you use struck tools without a helper. Once you have some hammer time you'll find you can adjust to different heights so long as it isn't extreme. I like different heights for different jobs, lower for hard striking and higher for finish work, say chasing. You can cut partway with a grinder and use a sledge hammer to snap it. I forgot that method earlier but it works a treat. Not too good for cleaning a rough torch cut though. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted June 12, 2013 Share Posted June 12, 2013 I'm thinking if I cut to between 1/4" and 1/8" and score the face with a cold chisel I should be able to get a fairly clean break. at least nothing a little grinder work wouldn't be able to clean up. Quote Link to comment Share on other sites More sharing options...
Michael Posted June 12, 2013 Share Posted June 12, 2013 I've run a lot of rail of different sizes thru my power hacksaw. Standard 12 inch blade and a lot of time. The back and forth pitman arm rhythm of an old PHS is very fitting for RR track. Quote Link to comment Share on other sites More sharing options...
John B Posted June 12, 2013 Share Posted June 12, 2013 If you take the sawing option, start from the base and leave the top work hardened bit 'til last.There was a previous lengthy discussion on cutting railroad track, including using cold chisels to score around the rail, and then snap it over bolsters/supports. One of the problems with rail is ascertaining the basic material, most methods quoted are non specific to your particular piece, so be prepared for all sorts of different outcomes.Another useful gadget used to straighten or bend rails was this Whatever you choose to do, it is a good learning experience. Quote Link to comment Share on other sites More sharing options...
Bryce Masuk Posted June 12, 2013 Share Posted June 12, 2013 A Concrete cut off is what they use to install them with a guide. a 70cc 2 stroke with a shop saw wheel on it basicly it will cut though one in 30 seconds or less and leave a clean cut Quote Link to comment Share on other sites More sharing options...
Bud in PA Posted November 13, 2023 Share Posted November 13, 2023 I have acquired a piece of rail track that I want to use in my press as a flattening die. What are the recommendations for cutting it in half? I have the usual 4 1/2 " angle grinder and an oxy/acetylene torch. I intend to use propane on the torch. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 13, 2023 Share Posted November 13, 2023 I have used my metal cutting band-saw and chop saw with good results when making a set of dies for the Star 30 pound power hammer. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
George N. M. Posted November 13, 2023 Share Posted November 13, 2023 Bud, I am not sure what you mean by I intend to use propane on the torch." If you mean using propane as a torch fuel instead of acetylene I think that might be a bad idea because the fuel/oxygen mixture is going to be different and the fuel side of a cutting torch is designed for acetylene. I'm not a welder but this sounds that it could be dangerous. Others who know more about gas welding and cutting will either confirm my suspisions or correct me. You can cut a piece of RR track with an angle grinner but it will take time and you will go through a number of cutting blades. It may be easier and cheaper to take it to a shop with a large metal cutting saw or a plasma cutter and have them do it. The problem with using a cutting torch is that it will give ragged ends but that may or may not be a problem for how you are intending to use it. If clean ends don't matter I would use and oxy/acetylene cutting torch. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 13, 2023 Share Posted November 13, 2023 The next time I need to cut RR track, I'll probably use the porta-band saw. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
Gazz Posted November 13, 2023 Share Posted November 13, 2023 Didn't I read somewhere that railroad workers used to score and break rail with a hammer? Seems impossible but I think I have come across that technique more than once in books or online. Myself, I've cut it with the gas axe before but it does leave a rather ragged edge. Quote Link to comment Share on other sites More sharing options...
mcostello Posted November 13, 2023 Share Posted November 13, 2023 Used propane to cut with for at least 20 years. Get the right tip. Quote Link to comment Share on other sites More sharing options...
Goods Posted November 13, 2023 Share Posted November 13, 2023 I’m assuming you’re using an oxypropane torch? In not, I’m very curious on the setup? Keep it fun, David Quote Link to comment Share on other sites More sharing options...
mcostello Posted November 14, 2023 Share Posted November 14, 2023 No oxypropane torch. Just get a propane tip and that's all You need. The flame is not as hot, 5100°appx. vs 5700° appx for acetylene. What's 600° among friends. Supposedly no good for gas welding, I don't use it for that. Cost is way cheaper, cylender doubles for BBQ cooking. Cutting flame is different, hold the tip a little bit further away. Quote Link to comment Share on other sites More sharing options...
