Pigsticker Posted October 2, 2022 Share Posted October 2, 2022 Kaowool liner Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 3, 2022 Author Share Posted October 3, 2022 I've got a new kaowool blanket for a lil 5x9x7 single burner forge Everyone has helpfully told me to enhance this plain blanket w kiln wash ridgidizer. Does anyone know 1 what quantities of each do I need 2 Do they make a kit 3 where buy the kit 4 with, blanket, ridgidizer, bricks and kiln wash do I have every single product needed to start and finish job. There's a water squirter in the kitchen. There always seems to be 1 more thing necessary wherever I find myself. Still got tons to study and learn but I wanted to get order in asap and get it headed my way. Wire rope arrives Tuesday Thanks and I'm still processing all the info my last question yielded me. Thanks for helping And 4 sides total or 3? Are Ttractor supply co's firebricks are ok? They're on sale this week for 4.99 I think. Been using a replacement one on the bottom under flame and it seems to "work" ok*. ( *Many helping have said fire might be lean) If yal have a chance Tx Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 3, 2022 Share Posted October 3, 2022 5lbs of Kastolite should be plenty, seal extra in an air tight container and save it in case you need more later. A pint can of Plistex should be more than you need seal and save extra for later. I don't use a firebrick of any kind in a propane forge but if you must then use a morgan k-26 and kiln wash it. Tractor supply fire bricks are for fire places and fire pits and rated MAYBE for 1,000f MAX. A propane forge will eat them like a 6 year old eats Halloween candy. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 3, 2022 Share Posted October 3, 2022 Especially if you are forge welding with flux. Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 3, 2022 Author Share Posted October 3, 2022 Thank you very much. Between thinking I needed bricks and not needing it was unclear. Would a brick still be a necessary thing on the bottom over this coating to protect it or is the coating a working surface? Will the effect on a cheap brick be only wearing away or could it explode? (I've still got 2 brand new tractor supply fire bricks I was gonna use as baffles) Tx for help, Will fire brick baffles definitely get my fire less lean. I want to place 1 order today w everything I need Tx Thanks ifcw. May e it's regular but the flux seems to become hard clumps all over the bottom when cooked and squirted on the floor of the forge. It doesn't scrape off in full heat unless I it's really scrubbed. Last time it took the brick w it. Almost feels like it welded with metal a little Tx again Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 3, 2022 Share Posted October 3, 2022 A fire brick that will tolerate forge temperatures is optional. I've been forge welding in the NARB forge for a couple years and if the flux on the floor starts being a problem I rake it out while it's still molten. The stuff sticks to anything so a bent rod will pick it right up. Scrape it off when molten, once it cools you'd probably damage the forge trying to chip it out. Kastolite and especially Plistex or Matrikote are high alumina refractories and are reasonably unaffected by flux. a 3,000f fire brick is a silica based refractory, molten flux will dissolve it after a while. A brick is optional it won't hurt a thing if you use one or not. Just don't use the ones from Tractor Supply your forge will get 3x hot enough destroy them in short order. Of course watching a brick crumble in a forge is kind of fun to watch. IF it's someone else's brick that is. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 3, 2022 Share Posted October 3, 2022 I don't believe firebricks affect the burn much, (lean vs rich, oxidizing vs reducing), unless that are blocking the exhaust so that the back pressure changes the induction of air. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 3, 2022 Share Posted October 3, 2022 Thanks Thomas I forgot to address that. The doorway thermal baffles keep the heat inside the forge. Similar to keeping the oven door closed. Rich vs Lean is a burner adjustment issue. literally the same thing as adjusting a carburetor. They're two different things. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 3, 2022 Author Share Posted October 3, 2022 Thanks guys. I watched a video(finally) on tuning burners but the video had a big debate if you could delean a forge with burner out or installed and I reAlized again what a big world it is. I was showing my optimistic side. Tx Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 4, 2022 Share Posted October 4, 2022 If you PM the link to the video to me I'll watch and let you know if it's good info or what most propane burner videos are. . . . Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 4, 2022 Author Share Posted October 4, 2022 Thank you sir. I'll use my internet savvy to try and send the video I watched. It'll take a few. Thanks for such a kind offer Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 4, 2022 Share Posted October 4, 2022 All you need to do is cut and paste the link in the address bar at the top of your screen to me in a PM. That way I can follow it to the video. It's not an unusual or special offer, we do this kind of thing for lots of people. Honest. Relax some okay? You don't have to keep thanking me. I do this all the time it makes ME feel good if I can help someone. I'm selfish that way you know. If it helps you too, it's a WIN WIN! Woo HOO! Maybe someday we'll meet up and can do a Snoopy Happy dance to celebrate! I just hope Deb doesn't video THAT! <SHUDDER> Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 4, 2022 Author Share Posted October 4, 2022 It seems like I get angry everytime I'm presented with anything. I sound like Ricky Ricardo with a southern drawl when I yell so it takes me back to living by the murmans. Thanks and sincere apologies for acting unappreciative . I owned up to bring an xxxxxxxx in first post but why am I suspected of tbi? (Joking) Did somebody on the forum give me a sponge bath? HIPPA protects me and you. (Not joking) (well a little) Tx Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 4, 2022 Share Posted October 4, 2022 Relax, you didn't yell. So you get frustrated, everybody does, it's no thing. No need to thank folks every time they make a suggestion or answers a question. Same for apologizing hold onto those until you REALLY need to get out of trouble. If someone on the forum is giving you sponge baths that's already too much information! Have fun but keep it to yourselves. . . PLEASE! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 5, 2022 Share Posted October 5, 2022 No, just that TBI is a fairly common reason for having impulse control. I'm an adult onset juvenile diabetic and so on insulin and have done the cranial concrete bounce test several times myself. I try to reread my posts before posting them just in case the monsters in my head have taken the reins in their teeth! (Been moderated for a typo before myself and am very thankful to the folks working to make this a site I can send kids to without worrying!) Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 5, 2022 Author Share Posted October 5, 2022 Morning guys. If I wrote a cuss I'm sorry. I thought I wrote the burro word in a private chat w Frosty. I guess I can't tell where stuff goes. Or maybe they read chats too? Indefinately!!! The bain of every often assumed tbi's life. And impulse control, I have some. Haha. To all reading please enjoy. I think finding matrikote had me delirious. Sorry all for cussing this appears to be a public post. At least I know one thing I'm not acting like. 5000 g. Or I can't tell yal. Quote Link to comment Share on other sites More sharing options...
Pigsticker Posted October 5, 2022 Author Share Posted October 5, 2022 CTToday's tip Make sure you're paying more than just a first and last name match on PayPal in you're paying on PayPal! Anyone, irretrievably, can be photographed and paid for matrikote But that's all ok here Quote Link to comment Share on other sites More sharing options...
buck369 Posted January 14, 2023 Share Posted January 14, 2023 Hi, i recently bought a cast masters smelting forge and trying to insulate it with the ceramic fiber blanket. I applied rigidizer first, heat treated it like the instructions stated and it became like stiff cardboard layer then applied satanite refracyory with 2 coats but each coat is cracking. I wanted to use itc 100 for the last coat but i dont know if i should scrap this and start over and maybe use fiber board instead of blanket. I believe its cracking because the blanket is able to flex but dont quote me. I just need some advice. Thank you. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 16, 2023 Share Posted January 16, 2023 I sure wish the myth of Satanite being a suitable furnace refractory would go away. Satanite is mortar, read about it on HWI's (the manufacturer) website. ANYBODY out there considering lining a forge, melter or other type furnace with Satanite. It may be rated to 3,000f but NOT in direct contact with flame. No, the Satanite is not cracking because the refractory blanket can flex. It is cracking because it's not supposed to be, #1 drying in open air and #2 be thicker than a layer of library paste between two bricks. If you can, break the Satanite out, you might be able to salvage the refractory wool, rigidize it and apply a proper flame face refractory. Kastolite-30 won't even need kiln wash in a melter. If you're planning on using a waste oil burner forget about the liner lasting very long burning oils of all kinds, the fames are extremely chemically active and tend to just plain eat refractories. Oil burning boilers, furnaces, etc are designed to have completely combusted both oil and oxy before coming into contact with anything but cast iron or stainless steel. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 17, 2023 Share Posted January 17, 2023 Are you sure it's a "smelting" item? Smelting is turning ore into metal. HOWEVER many people are using it incorrectly when they mean melting---turning metal into liquid metal for casting. Quote Link to comment Share on other sites More sharing options...
